most economic way to raise the rear of 91 f350 srw?
as title says, i have a 91 f350 8ft bed, crew 2wd SRW. not sure if 3/4 or 1 ton (how do i check?)
I have heard of a shackle flip to raise the rear. Im looking to raise it approx 3-4 inches. What exactly does a shackle flip entail? I have a welder, metal, and lots of time and patience.
Im very new to the truck world, please be patient with me
on
Firstly, if you have an F350, then it should be a one ton. The rear axle should also be a full floating type, which means the axle ends stick out past the rims center about 4 or 5 inches.
I think, the front suspension would NOT be the TTB on a 2wd one ton as well?
As for raising the rear, is it for looks or other reasons? You could put a lift block in, which I think would be a lot easier than a shackle flip. But seems to me that it would negatively affect the handling of the truck. Either way, you would also have to change out the shocks to match the additional hight.
I don't think I would raise it more than 2 inches myself...
An F-350 is a one-ton truck. An F-250 is a 3/4 ton truck. Always.
Are you planning on lifting the front of the truck as well? Your truck will look really silly with the rear jacked up 4" and the front at stock height. Your headlights will point at the ground in front of you. Why do you want this? Are you trying to get more load capacity?
sorry fo the confusion guys, im all new to this and not familiar with the terminology yet.
those parts store guys, i tell em its a 350 and they ask if its 3/4 or 1 ton, i always said 1 ton (i assumed it was since its a 350 and a friggin diesel).
here is why i want to raise the rear
as you can see, the rear sits lower than the front (previous owner put some huge *** springs up front, and the camber bushings are maxed yet i still have massive positive camber)
Also, i wouldnt mind a slightly raked look (nothing crazy though).
I want the rear to be AT LEAST level with the front, if not 1-2" higher.
my friend said i had TTB (dont even know what it stands for), but this truck does in fact have twin I beams (i think)
its a bad angle for this, but it seems the springs are almost or only 0.5" from the rear axle, so i could put a 2" block under there (im not a fan of blocks though).
thanks for the input so far guys, keep it coming please
Parts store guys are pretty clueless in general. That doesn't surprise me.
Your friend is also wrong, a TTB (twin traction beam) is the four-wheel drive version of Ford's twin I-beam front suspension.
For your problem, I would get a couple of lift springs from an offroad/4x4 shop near you and put them in. You will also need longer shocks. That will get everything looking right again. Your other option is to put a set of stock front coils back in. That will also correct your alignment problems.
lift springs cost money, how does one go about foing a shackle flip?
Ford Rear Shackle Flip Kit - Sky's Off-road Design
