Factory subwoofer upgrade? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 01-22-2013, 08:30 AM
bryced15's Avatar
bryced15 bryced15 is offline
bryced15 is gaining momentum as a positive member of FTE.bryced15 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Sean Nederfield View Post
I did the same upgrade last month.
The connector has audio, A+,ground. The switch power to turn the amp on is only 5 volts so it did not work to turn the amp on. I had to run a switched 12 power line back. I just tapped off of the radio fuse and ran the wire back.
It was a great install. I noticed a huge difference. I had also upgraded the 4 door speakers earlier.
I'm totally audio ignorant, so do you recall what colors were what wires when you did this?
  #62
Old 01-22-2013, 11:54 AM
RobFlag RobFlag is offline
RobFlag is gaining momentum as a positive member of FTE.
I installed this amp and the remote turn on works. Kinda scares the crap out of you the first couple of times it turns on with a big THUMP coming from the back seat area.
Amazon.com: Rockford Fosgate R500-1D Prime 500 Watt Mono D-class Amplifer: Car Electronics Amazon.com: Rockford Fosgate R500-1D Prime 500 Watt Mono D-class Amplifer: Car Electronics
Replaced the factory driver with this. Thought I had ordered the 8" but when the 10" arrived, I figured out a way to make it work in the stock box. Combination of this driver and amp rock pretty well for a cost effective system.
Amazon Amazon
Probably should have upgraded the power wiring to the amp, specs call for 4 gauge and I used the factory 16ish gauge.
  #63
Old 01-24-2013, 10:19 PM
Sean Nederfield Sean Nederfield is offline
Sean Nederfield is starting off with a positive reputation.
bryced15,
There is 5 wires to the factory amp mounted on the sub box.
Green/white Audio -
Violet/green Audio +
Blue/Red (heavier wire) Alway hot power wire for the amp A+
Black/yellow Ground
Violet/red is the switched power to turn the amp on. This is the wire that will not work as it only has 5 volts on it. I just capped it off with a piece of heat shrink tubing. The amp requires 12 volts to turn it on. I ran a wire from the fuse box with a fuse tap from the radio fuse. When the key is turned on it gives 12 volts to the amp and turns it on.
I hope this helps. I got a Ford schematic from another member posted on another thread. I will look and try to find the link.
Sean
  #64
Old 01-24-2013, 10:45 PM
Here is a link to the thread from 2000silverbullet with a PDF of the Ford factory schematic. It gives you all of the wiring and color codes.
I hope this link works.
http://www.ford-trucks.com/forums/98...bwoofer-3.html
  #65
Old 01-25-2013, 06:27 AM
bryced15's Avatar
bryced15,
Green/white Audio -
Black/yellow Ground
Sean
Thanks! That's just what I needed to know.
  #66
Old 01-25-2013, 06:37 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Quote:
I would seriously consider running new wires...
  #67
Old 01-25-2013, 08:04 AM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
That will lead to either the wiring failing due to overload or the amp failing prematurely due to inadequate power supply and it choking itself. I've seen wiring get overloaded so much it melts the jacket off and shorts the first piece of metal it meets. Your truck, your rules, but you are on borrowed time in my opinion.
  #68
Old 01-25-2013, 10:21 AM
bryced15's Avatar
Quote:
Ok good call. I'm going to run a 10 gauge power from the battery. That's what my amp calls for. Thanks for all the good advice.
  #69
Old 01-25-2013, 11:00 AM
_red rocket_'s Avatar
_red rocket_ _red rocket_ is offline
_red rocket_ is gaining momentum as a positive member of FTE._red rocket_ is gaining momentum as a positive member of FTE.
Green/white Audio -
Black/yellow Ground
Thanks for the pinout info.
  #70
Old 01-25-2013, 02:54 PM
jetpilot2's Avatar
jetpilot2 jetpilot2 is offline
jetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to behold
Here's my upgrade plus all the door speakers! For as nice as these trucks are, Ford has THE WORST audio!!! It was the same way in my f-150.
  #71
Old 01-25-2013, 03:01 PM
SavageNFS's Avatar
not a WHITE truck
That looks great George!
  #72
Old 01-25-2013, 03:15 PM
jetpilot2's Avatar
Thanks Andre!
It sounds even better!!!
  #73
Old 01-25-2013, 03:42 PM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
Awesome George. That's pretty much what mine looks like except I made two enclosures instead of one long one. The driver side box is an L shape for that window motor.
  #74
Old 01-25-2013, 04:03 PM
jetpilot2's Avatar
Joel,
Mine was bought. There's a company that makes them for our trucks and I just took it in to the audio shop, they ordered it and did the complete install. I just don't have the time to be messin' with the stuff right now; and it's easier that way too!!
  #75
Old 01-25-2013, 04:55 PM
ruschejj's Avatar
Ya, I know what you mean. I kind of need a new head unit to replace my factory nav. I'm seriously considering having it done. I really don't want to tear into that dash.....
Need recommendation on amp, subs, components F250 Henry42 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 02-06-2016 03:54 PM
Stereo rookie with 2012 F350 sub question B&LLandscaping Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 7 09-26-2013 02:31 PM
'11 f150 speaker/sub options... ProgDrummer79 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 06-10-2011 09:59 PM
Need suggestion and advice for 2009 Supercrew with...... des929 2009 - 2014 F150 9 10-12-2009 11:44 PM
6 disc in dash - no bass? Fordtrucktexan Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 8 05-25-2006 02:11 PM
Tags
2001, 2006, 2010, add, davidson, escape, f150, f250, factory, ford, harley, lariat, oem, saleen, size, subwoofer, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
