Factory subwoofer upgrade? - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 11-27-2012, 11:15 PM
RobFlag RobFlag is online now
RobFlag is gaining momentum as a positive member of FTE.
Damn you guys, now I've got another To-Do on my list for the weekend. Just ordered the parts.
  #47
Old 11-29-2012, 11:11 PM
ForemanES's Avatar
ForemanES ForemanES is offline
ForemanES is gaining momentum as a positive member of FTE.ForemanES is gaining momentum as a positive member of FTE.
I have a Kicker L5 10" sub (those square ones from like 5 years ago) and a 450rms rockford fosgate amp that I pulled from my old truck. Its just sitting in garage itching to be installed. From all my measuring and reading I don't think its possible
The dang thing is 6.25 in deep which is about 1" too deep for the supercrew sound custom box.
I'm contemplating trying to sell this sub for probably nothing and getting something that would work.
OR just installing 8" sub in stock ones place for <$100.
My only beef with the stock sub is the higher you turn the volume up the less output it seems to have.
  #48
Old 11-30-2012, 01:26 AM
Completed my upgrade last night. I inadvertantly ordered the wrong sub (MB Quart Reference RLP254) which was a 10" driver. Was able to make it fit in the stock box (for now, seriously considering something more substantial) though generous use of a sabre saw and some MDF filler. Also used a Rockford Fosgate R500-1D amp. Little too large to fit in the stock location on the sub enclosure but packs quite a punch. Only challenge is the "Enable" wire going to the stock sub amp won't "enable" my new amp to turn on. Right now I've got it wired so it's on all the time but don't want that for long since it'll kill the batteries. Looks like I'll need to find a way to provide a switched 12VDC to turn on the amp. Anyone have a good idea where I can find one in the vicinity of the sub enclosure?
  #49
Old 11-30-2012, 06:56 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Were you able to find a mini fuse tap? That w/ a test light and you'd be done in about 10 minutes (most of which would be spent snaking the wire through the door channels).
  #50
Old 11-30-2012, 09:08 AM
Matt, haven't have a chance, had to leave on a work trip and won't be back till next Friday so I can do some more digging.
  #51
Old 11-30-2012, 10:58 AM
I hate when work gets in the way of truck time.
BTW, offtopic, but I see you're in Flagstaff, I used to snowboard at Snowbowl alot before I moved to PA. The hills out here are pathetic compared to Snowbowl/Sunrise...
  #52
Old 11-30-2012, 01:34 PM
Continuing off topics, I board there too. They installed snowmaking equipment this year so from now on, season should run from T-giving - April every year!
  #53
Old 12-05-2012, 05:40 PM
frdf250's Avatar
frdf250 frdf250 is offline
frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.
can anyone who mounted a bigger sub behind there seat post a picture up of how they mounted it/what it looks like. just would like to get an idea.
  #54
Old 12-05-2012, 05:44 PM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Check out this site: spl2k
  #55
Old 12-05-2012, 06:19 PM
darren32's Avatar
darren32 darren32 is online now
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
Quote:
There is a pic of mine here:
http://www.ford-trucks.com/forums/11...l#post11693963
  #56
Old 12-06-2012, 09:17 PM
cirrus365's Avatar
cirrus365 cirrus365 is offline
cirrus365 is gaining momentum as a positive member of FTE.
Has anyone just upgraded the speaker not the amp? any benefit?
  #57
Old 12-06-2012, 10:46 PM
I did both but have to believe that it would help. The stock driver is mighty lightweight.
  #58
Old 01-21-2013, 05:27 PM
bryced15's Avatar
bryced15 bryced15 is offline
bryced15 is gaining momentum as a positive member of FTE.bryced15 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by dfred View Post
Sub model is RLP204, $69 at sonicelctronix.com
Amp is PBR300X1, $159
Punch PEQ (small equalizer really works) $29
The polyfill tricks the sub into thinking there is more air space in the box than really exists..dont how it just does.
set up is really easy, I dont recall the wiring color match ups, do a search on the site there is somone that put together a good write up on the install of the amp using the stock wire harnes...the signal is taken from both rear speakers....
pair this up with the infinity speaker upgrades and the difference is great. BTW I used the blue trailer wire clips to splice in the back door tweeters to the leads into the rear infinity speakers, worked great, didnt have to llose the tweeters with the speaker upgrade. jusst clip them to the speaker lead right befor the connection to the speaker.
I'm going to be doing this same thing. Not sure on the wiring though. I noticed the factory sub harness has 5 wires in it. How did you wire up to the Rockford amp?
  #59
Old 01-21-2013, 09:15 PM
Sean Nederfield Sean Nederfield is offline
Sean Nederfield is starting off with a positive reputation.
I did the same upgrade last month.
The connector has audio, A+,ground. The switch power to turn the amp on is only 5 volts so it did not work to turn the amp on. I had to run a switched 12 power line back. I just tapped off of the radio fuse and ran the wire back.
It was a great install. I noticed a huge difference. I had also upgraded the 4 door speakers earlier.
  #60
Old 01-22-2013, 06:17 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
I just measured the area behind the seats, built two enclosures myself, took the seats out, and put them in. I think there are some pics in my albums.
Been running them two years now, maybe a little more than that. Love it.
Need recommendation on amp, subs, components F250 Henry42 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 02-06-2016 03:54 PM
Stereo rookie with 2012 F350 sub question B&LLandscaping Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 7 09-26-2013 02:31 PM
6 disc in dash - no bass? Fordtrucktexan Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 8 05-25-2006 02:11 PM
Custom Sound System srob 2004 - 2008 F150 26 01-12-2004 11:07 PM
Frequency settings for clarion dxz725 GuyOutWest Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 12-19-2002 07:46 PM
Tags
2001, 2006, 2010, add, davidson, escape, f150, f250, factory, ford, harley, lariat, oem, saleen, size, subwoofer, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
