Factory subwoofer upgrade? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-08-2012, 11:48 AM
TexasA&M's Avatar
TexasA&M TexasA&M is offline
TexasA&M is gaining momentum as a positive member of FTE.TexasA&M is gaining momentum as a positive member of FTE.
Look at my post #13 for a good solution.
  #32
Old 05-08-2012, 11:51 AM
gsxr1300 gsxr1300 is offline
gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.
Jul audio makes a small enclosure with the 8" sub you mentioned that fits behind the seat
  #33
Old 05-16-2012, 12:01 PM
Darren sent me his stock sub Thanks!
the box measurements are 24 1/4 long X 10 1/4 tall
bottom depth 6 1/2 tappers to about 5
  #34
Old 05-16-2012, 12:06 PM
Dual voice coil sub
  #35
Old 05-16-2012, 12:09 PM
jetpilot2's Avatar
jetpilot2 jetpilot2 is offline
jetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to behold
Quote:
Originally Posted by gsxr1300 View Post
Dual voice coil sub
Cool! Well wait to see the "installed" pics.
  #36
Old 05-16-2012, 12:12 PM
stock box seems kinda cheap plastic I dont think upgrading the woofer only would be a good option
  #37
Old 05-16-2012, 12:17 PM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
No, it is very easy to build your own enclosure to fit behind the seat, get a 10" speaker and an amp, tap into rear main speaker channels for source and you're done. Most sealed enclosures need to be within .66 and 1.00 cubic foot (interior air volume).
  #38
Old 05-16-2012, 12:20 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Could try it, I don't think you would be that happy with the results.
  #39
Old 05-22-2012, 08:28 PM
has anyone measure the space under the rear seat if you removed the storage box?
  #40
Old 11-24-2012, 11:36 PM
Sincitysupercrew Sincitysupercrew is offline
Sincitysupercrew is starting off with a positive reputation.
Replacing subwoofer
Did you ever swap out the factory sub ... If so How did it sound .
  #41
Old 11-26-2012, 05:57 PM
dfred dfred is offline
dfred is starting off with a positive reputation.
I changed the factory sub and amp out reusing the OEM enclosure....sounds pretty good.
I changed the sub out with a MB quart shallow mount, dropped right into place. I did put some polyfill in the box as well. Replaced the amp with a Fosgate PBR 300x.1 with the remote, again fit right where the old OEM unit was mounted on the box.
I'm not going to blow any windows out but the improvement was very drastic and did not require removing the seats to get the box out, just lay the seats forward, take out the four bolts and work the box out.
  #42
Old 11-26-2012, 07:22 PM
RM2012F350's Avatar
RM2012F350 RM2012F350 is offline
RM2012F350 is starting off with a positive reputation.
MB quart shallow mount, What model?
polyfill in the box as well...What is this?
Forgive me but I am stereo illiterate to the point of retardation...I like plug and play
  #43
Old 11-26-2012, 10:00 PM
_red rocket_'s Avatar
_red rocket_ _red rocket_ is offline
_red rocket_ is gaining momentum as a positive member of FTE._red rocket_ is gaining momentum as a positive member of FTE.
Polyfill is the fibrous material that looks like cheap pillow stuffing and is frequently used to simulate ground snow at your local indoor mall Santa's Village.
I would also like to know what the model numbers are for the sub and amp you used for the direct replacement using the OEM box. Thank you as it will be very helpful.
  #44
Old 11-27-2012, 10:19 AM
Sub model is RLP204, $69 at sonicelctronix.com
Amp is PBR300X1, $159
Punch PEQ (small equalizer really works) $29
The polyfill tricks the sub into thinking there is more air space in the box than really exists..dont how it just does.
set up is really easy, I dont recall the wiring color match ups, do a search on the site there is somone that put together a good write up on the install of the amp using the stock wire harnes...the signal is taken from both rear speakers....
pair this up with the infinity speaker upgrades and the difference is great. BTW I used the blue trailer wire clips to splice in the back door tweeters to the leads into the rear infinity speakers, worked great, didnt have to llose the tweeters with the speaker upgrade. jusst clip them to the speaker lead right befor the connection to the speaker.
  #45
Old 11-27-2012, 10:54 PM
Very cool. Thanks.
Need recommendation on amp, subs, components F250 Henry42 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 02-06-2016 03:54 PM
Stereo rookie with 2012 F350 sub question B&LLandscaping Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 7 09-26-2013 02:31 PM
6 disc in dash - no bass? Fordtrucktexan Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 8 05-25-2006 02:11 PM
Custom Sound System srob 2004 - 2008 F150 26 01-12-2004 11:07 PM
Frequency settings for clarion dxz725 GuyOutWest Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 12-19-2002 07:46 PM
Tags
2001, 2006, 2010, add, davidson, escape, f150, f250, factory, ford, harley, lariat, oem, saleen, size, subwoofer, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
