Factory subwoofer upgrade?
on
All yours, PM me the shipping address and I will fire it off.
If I google the part number for the amp (8A5T-18C808-AB) I get this:
PAM's Auto, Inc. - Radio Audio : MILAN 10-11 amp, ID 8A5T-18C808-AB
If that be the case then it is 10 amps??
Prob not worth putting a better sub in then with only 10 amps to power it.
Looks like ford uses this little amp on quite a few vehicles.
Thanks
Thanks
Thanks
Thanks
I wouldn't be so quick to dismiss the stock amp.
10-11 amps X ~12 volts = 120-150 watts. That's close to the one TexasA&M posted, and not completely unreasonable for powering an 8" sub if it's a mono D rated amp from what the research I've done would tell me. The lack of any tuneability on the stock amp looks like biggest drawback to me.
I think I'll be going ahead and trying a simple subwoofer upgrade to start with and then replace the amp if I'm not happy with it.
I have not looked at the OEM sub but suspect there is no spec info on it.
This is the one I have my eye on if it will fit -
JL Audio 8W3v3-4 8" 4-ohm Component Subwoofer
Pricey, but I only want to do this once.
It takes about 2 minutes to figure out that the factory sub is a joke. Sounds good at very low volume but if you want to enjoy what you're listening to, forget it.
I have one too if anybody wants it. Been sitting in a box for almost 2 years now.
Get some subs installed or tackle it yourself. It is not hard, just a little insecure at first.
Then get your steely Dan, dave Matthews, or Korn out and enjoy!.
on
That would be really simple with the wiring already there.
#28
#29
I just had a kicker 10" added behind the rear seat. Huge difference over factory. Had kicker speakers put in as well. The stock system was a joke.
Wasn't looking for earth shattering base but a good sub makes a huge difference.
They made a box for a 2001 F150 and the guy changed his mind. It happened to fit my F250 very well. A little tight but it fit.
#30
Finally got around to having a good look at the truck last night, only to find out that much to my dismay, I don't even have a factory subwoofer.
I'll be looking at installing a small powered unit behind the rear seat or maybe under the passenger seat depending on what I can find. There seems to be lots of off the shelf 8" sub options out there that will give me all the bass I want and not take up a ton of space.
