Installed Aries Bull Bar and PIAA driving lights
I spend all day Saturday installing the bull bar and lights...just a heads up for everyone...install the lights on the bar first, then put it on your truck...then run the wires after you get it on. I used the AUX 3 upfitter switch for control, and used the firewall pass through you see in the pics to run the wires into the cab. If I had to do it again, it would take me a quarter of the time...but such is learning!
Let me know if you have any questions guys!
Thanks for looking guys!!
Looking good !!!
I miss the PIAA 520's I had on the Ex - they would light up the night well !!!
On the Ex I was able to just screw the plate into the grill body a bit higher so it could be seen thru the bull bar and never had a problem,
but I did have to relocate the fog lights to below the bull bar:
https://www.ford-trucks.com/user_gal...=25206&width=2
On a side note, I spent about an hour on Google Earth looking over all my old stomping grounds; man have things changed in 20 years. I sure loved Houston but the oil debacle and the construction industry tanking forced me to move on to college, and never made it back for a job after that.
Post a pic with the relocater on when you get it.
I am in Houston also, far west side inside Hwy 6 and Westheimer. When I put my bull bar on I took the license plate off and dont plan on putting it on untill Im forced to! I used the Aux 3 upfitter also, why didnt you use the factory pass thru wires for your lights?
bad_habit_F350
16
06-02-2020 10:54 PM
YellowSled
10-03-2010 12:20 PM
leviticus
07-12-2009 01:25 PM
