Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 05-02-2012, 09:14 PM
ADPSMP ADPSMP is offline
1961 Ford F-100
ADPSMP is starting off with a positive reputation.
Brake Upgrade Questions
I have a 61 Uni that I am planning on doing a complete brake upgrade on. I do have a couple of questions that I have been unable to answer using "search".
-Where is the best place to pull vacuum for a dual-bowl power master cylinder upgrade? (I can't see any vacuum ports on the intake manifold or on the carb)
-If no port exists, is it better to tap into the intake manifold for vacuum, or to ad a spacer under the carb and get vacuum that way?
Thanks for any help.
  #2 (permalink)
Old 05-02-2012, 10:05 PM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
Garage is empty, add now
jacks61ford is starting off with a positive reputation.
pull vacuum ??Are you doing power brakes
  #3 (permalink)
Old 05-03-2012, 03:28 PM
1961 Ford F-100
I'm planning on upgrading to this:
Classic Car and Truck Brake, Steering and Suspension Parts
  #4 (permalink)
Old 05-03-2012, 05:39 PM
pburress's Avatar
pburress pburress is offline
1963 Ford F-100
pburress is starting off with a positive reputation.
I just installed that unit on my '63 Unibody with the inline 6. On my intake manifold there was a fitting hole that was plugged. I got a brass fitting and ran the vacuum from there. You can see it in the pic.
It was a great upgrade and my (4 wheel drum) brakes work great now. A huge upgrade.
Do yourself a favor and inspect your wheel cylinders- mine were totally full of gunk and dirt. New replacements were less than $15 each.
Here the thread where I talked about my project: http://www.ford-trucks.com/forums/11...questions.html
Nice looking truck by the way.
Click the image to open in full size.
  #5 (permalink)
Old 05-03-2012, 07:16 PM
1961 Ford F-100
Thanks for the pics, info, and compliment...
I plan on replacing the entire brake system all at the same time. I have the disc brake conversion kit for the front, and I plan on replacing both rear drums, wheel cylinders, and hardware, along with all new brake lines.
  #6 (permalink)
Old 05-03-2012, 07:39 PM
that sounds awesome should stop great can't wait to see how it turns out
  #7 (permalink)
Old 05-12-2012, 02:32 AM
PetesPonies PetesPonies is offline
PetesPonies is starting off with a positive reputation.
Problem I see is that MC has the same size reservoir front and back. Which means its is set up for either all disc ( 4wd as in the Corvette it came from ) or 4 wheel drum. If you plan on using a disc/drum setup . . there needs to be a disc/drum MC. Also, if using this Corvette MC on a 4 wheel drum setup . . where is the residual valve needed for drum brakes?? Many times that valve was in the port of the drum brake MC. How have they incorporated that in the Corvette MC ??
__________________
Pete's Ponies
Mustang RUSToration & Performance
  #8 (permalink)
Old 05-12-2012, 07:00 PM
1961 Ford F-100
I believe the one in the pic is specific to the drum/drum set-up. They are also available in a disc/drum and disc/disc set-up. They have the proportioning valve built in according to Classic Performance.
I ordered the one that is designed for the disc/drum setup...so we will see.
  #9 (permalink)
Old 05-12-2012, 07:11 PM
I think you are right, which is why I said what I said. Is there a pic anywhere of a MC that is DEFINITELY disc/drum from them???
__________________
Pete's Ponies
  #10 (permalink)
Old 05-13-2012, 07:22 PM
Scout Pilot's Avatar
Scout Pilot Scout Pilot is offline
1962 Ford F-100
Scout Pilot is starting off with a positive reputation.
Please Post pictures throughout your process. I would also like to do this.
  #11 (permalink)
Old 05-14-2012, 05:45 AM
larryejoh larryejoh is offline
larryejoh is starting off with a positive reputation.
Nice picture Scout Pilot. I used to be a maintenance test pilot on OH-58's.
  #12 (permalink)
Old 05-14-2012, 12:17 PM
1962 Ford F-100
Campbell guy?
  #13 (permalink)
Old 05-14-2012, 01:47 PM
Was station there when I retired in 97. I was in the 2/17 Cav. I flew A, A+,C and D model OH-58's along with UH-1's.
  #14 (permalink)
Old 05-14-2012, 04:53 PM
1962 Ford F-100
I am up here at Drum in 6/6 Cav. 9 years to go.
  #15 (permalink)
Old 05-14-2012, 04:54 PM
1962 Ford F-100
Adpsmp,
How much did power brake kit cost? The wibesite is acting up and I cant get a cost to cost up. I am really tired of braking over a quater mile from the stop signs.
Tags
1961, bad, brake, cost, ecoboost, f100, f150, ford, forum, inline, intake, kit, manifold, power, rust, truck, upgrade, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
