Cranks/no start/no spark
Hey all,
Got a '90 F250 2wd 351 auto that I'm working on for my neighbor. I'm a mechanic, but this one has me pulling my hair out. I know I'm missing something stupid, but I just can't figure it out. I have searched and searched this site and others today, tried almost everything and still can't figure it out.
I've got fuel, I've got injector pulse, I've got battery voltage to the coil, I've tried two other coils, one new/one known good, I replaced the pickup in the distributor, but really couldn't see how that would be it since I had injector pulse. I just plain do not have any spark coming out of the coil. Once in a while I might get a little, but I'd really call it none. The truck actually ran for about a minute yesterday, then died. I can't get a pop, backfire or anything out of it. The truck just died going down the road. Why can't I get any spark?
Help!
Travis
Help!
Travis
Travis
That implies the PIP is instructing the module to fire the coil, and implies your problem lies between the coil and the plugs. I'd check the distributor cap & wires, especially the center wire connecting the two.
However, a brighter light there than at the other side might also indicate bad connections or wiring to there.
I don't know anything about Snap-On test lights being brighter or dimmer than any others....
Travis
Edit: Some Snap-On test lites seem to light up pretty good even with low voltage, which can fool a guy sometimes. I've had mine several years and I'm used to it, but my instructor for Specialized Electronics Training demonstrated this in one class. Out of three different test lights, the cheaper ones seemed more "accurate" if you wanted to eyeball the voltage.
So, you have output from the coil so there is no need for a primary and secondary resistance check on the coil.
you already did a PiP/tfi check circuit check
you have output from the coil so an ignition coil voltage supply check is not necessary.
Did you do a spout to ground check as well?
when you checked the TFI/pip did you examine the condition of the spade terminals, were they loose or carbonized? Is the rotor defective? Bad #9 wire connection?
