Vacuum leak? - Ford Truck Enthusiasts Forums
Vacuum leak?
Old 05-02-2012, 06:30 PM
seawulff seawulff is offline
seawulff is starting off with a positive reputation.
Vacuum leak?
I haven't been active for awhile and started driving my '56 F100 recently since the weather is better. Whenever I accelerate, but more so when the engine is cold, there is a delay/near stall when I step on the accelerator pedal. If I accelerate slowly it is much less noticeable. Sometimes when idling I hear a faint high pitched whistling sound. Does this indicate anything in particular to anyone? The carburetor has been rebuilt <250 miles ago. The engine is a '57 312 if that makes any difference. I put in an electronic ignition conversion awhile ago and this is a new problem. When I listen under the hood while idling I don't really hear anything different but there's a lot of noise in that compartment! Thanks.
Old 05-02-2012, 06:41 PM
brain75's Avatar
brain75 brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
carb rebuilt 250 miles ago... did you keep the old leather accelerator pump or put in the new cheepo plastic? I put in the cheepo plastic and have it planned to tear it back apart this weekend after 500 miles of troubleshooting and hating on it (thankfully I saved the old parts).
a whistle like that could very well be a vaccum leak and that would also be a candidate, but what you describe "hesitation when you step on the pedal" is most likely accelerator pump.
If you have the leather, soften it up with mink oil maybe even "toast" it (not really toast, just warm it up to about 100 degrees so the pores open up) to get the oil to soak in.
mechanics stethascope (sp) blocks out the engine noise and you can wave the end around near all the typical parts of the carb. I found a tiny leak in mine that way and resolved it, but still the hesitation.
Old 05-02-2012, 06:58 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
[quote=seawulff;11784253 there's a lot of noise in that compartment! Thanks.[/quote]
Remember, you're hearing a Y block with those mechanical lifters.......Music
Make sure your advance is working. Might move the pump linkage to get more fuel.
Old 05-03-2012, 10:24 AM
petemcl's Avatar
petemcl petemcl is online now
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Quote:
If you don't have a stethoscope use a 2' length of pipe.
Old 05-03-2012, 11:27 AM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
How long has the 312 been sitting? Even a few months through the winter I have had gaskets shrink up and leak thus causing a vacuum leak.
Try getting her warmed up and gently re-torque the intake and carb base.
And I agree on a bad accelerator pump as well.
Old 05-03-2012, 11:44 AM
yamagrant's Avatar
yamagrant yamagrant is online now
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
Back in the day Rochester 4bbl's were notorious for their accelerator pump's drying out, we would add a 1/2 quart of tranny fluid to the gas tank. We found this worked 90% of the time, and told the cust to do this every 3rd or 4th tank. It also is good for getting rid of carbon.
Fuel pressure issues Tyler.172 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-19-2016 05:22 PM
03 Expy slight rattle/tick while in drive at idle with the brake on ScottyDsntKnow 1997-2006 Expedition & Navigator 1 03-09-2015 05:59 PM
Help! 1994 4.0L Ranger misfiring & hesitating under load? danmm7 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 14 02-19-2015 01:30 AM
'89 F250 Surging Rough Idle Dies Ariela 1987 - 1996 F150 & Larger F-Series Trucks 0 04-08-2014 11:20 PM
1978 Ford F150 4x4 JakefromStateFarm 1973 - 1979 F-100 & Larger F-Series Trucks 15 02-17-2014 03:02 AM
Tags
312, accelerator, block, ford, hesitation, kind, leaks, leather, oil, pump, soften, vacuum, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
