Does a leveling kit simply raise the front end? Does it actually raise the truck at all? Who makes the best leveling kit for 2WD? Thanks.
Leveling kits are simply spacers that go on top of the coil spring. They come in 1.5" - 2.5" heights. If you go as big as 2.5" you'll want 1" add on or 350 blocks in the rear.
Will just raise the front so the rear wheel well spacing will be the same as the front. Just measure the differences and find one that fits what you need.
