Lightning 351W to 408 stroker build - Ford Truck Enthusiasts Forums
Old 05-02-2012, 11:38 AM
Rockaholic Rockaholic is offline
Rockaholic is starting off with a positive reputation.
Lightning 408 Stroker Build
-Piston: Forged aluminum flat top made specifically for twisted wedge heads
Head volume of -3.0cc
Base bore of 4"
Compression height of 1.280"
-Moly File fit rings
-Forged steel crank
4" stroke
3" main journal
2.1" rod journal size
-Clevite H-Bearings
-Forged steel lightweight I-Beam rod
6.2" length
-Trick Flow aluminum twisted wedge heads
Combustion chamber 65cc
Intake Runner 225cc
Exhaust Runner 100cc
CNC machined intake and exhaust runner
Heart shaped combustion chamber
Intake valve diameter is 2.08"
Exhaust valve diameter is 1.6"
More to come, still working on what i am going to build the heads up with. Any idea on intake valves, valve springs, damper springs, retainers, locks, valve stem seals, rocker arms and rocker studs, guideplates? Nornally order a pre built head but i want this to be fully customized. Will be my D/D and i need it toLAST!!!!! They people i am buying my parts from say the kit will go 100k plus as long i am not pushin 1000+ hp out of it the whole time. They say stay below 900 to the tires and i should be ok to drive it for many many many years to come. My overall build i am only looking for 5-600hp and 600+tq to the tires.
Any ideas on a custom grind cam with specs for this motor? Want a nice duration for lope. Will be ran with an independent efi system(F.A.S.T 2.0) so no problems to worry about there. Will be street driven so need it to be street friendly, this is a build i am getting started with as i post this. Ordering current parts now but just want some input on everything else. i am looking for a descent curve with the cam specs and i will not be revving this thing more than 5k daily but at the track will go to 7k maybe 7.5k if it will let me so power band preferred to stay in 3-6 range for peak and constant power. Will be a lot of highway as well so don't want to be doing 80 and pushing 3k rpm. like to cruise at 1.5-2k rpm at 80 in over drive. Rear is still a 4.10 but will probe drop to 3.73 if need be but would prefer not to touch it. My drive train from main seal back is built. Ford 8.8 with 31 spline 4.10 reinforced rear, with custom valve body and built internals on my trany.
Any input is welcome, thx.
This is for a 1995 Ford Lightning btw if anyone was curious. SUCH A SLEEPER!!!
Old 05-02-2012, 04:44 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
a 5.0 roller cam really wakes these engines up
Old 05-02-2012, 05:31 PM
Was def going to be a roller cam, i have the F4TE block for it already. Just needing to decide on cam specs.
Not sure what i should go with.
Old 05-04-2012, 02:19 AM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
At least .550 lift.
Old 05-13-2012, 10:57 PM
Quote:
Originally Posted by 88dually View Post
At least .550 lift.
Dang, that is a **** load. Someone told me .450 would be descent. I will do some more research. Talking with the guys at coast high about doing a dart short block from there. Not sure if it is worth my money yet unless we can work something out. Will end up being a big bore 428 which is a 4.125 bore with a 4.0 stroke making it a total of 428ci but using a 408 stroke. Better block, more cubes, warranty, its like a dream hahahaha
Old 05-14-2012, 11:47 PM
Will eventually boost this motor but only in time. Was a bit curious tho because i am changing the heads i want to use. Want a bit more on the intake. Looking at the trickflow 240cc.
But i have been doing some research and getting mixed answers. What is a descent size chamber to run? Trick Flow Specialties TFS-5170T016-C02 - Trick Flow® High Port® 240 Cylinder Heads for Small Block Ford - Overview - SummitRacing.com
Those are the ones i am looking at but not sure what a descent compression would be to run. Turbo will be mounted under hood so wonthave to worry to much about spool but what is a descent compression ratio to stick with? Will be on pump gas 93/106(93 mostly but on occasion additive) octane and e85 at drag.
Looking for More HP for my 545 . . . F350 Strait Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 05-17-2010 01:21 PM
Heres what im thinking...393 stroker time. 70torino429 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 06-25-2009 06:46 PM
408w build-up, anybody got desktopdyno?? jerg_064 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 24 05-28-2009 04:19 PM
performer heads for stroker 408 ljeeper Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 04-15-2008 11:10 PM
TFS Twisted Wedge or AFR185's? 408W stroker :) alk3myst 1978 - 1996 Big Bronco 14 09-11-2003 12:17 PM
Tags
351, 351w, 408, 408w, 58, build, connecting, engine, ford, lightning, power, rod, stroker, strokers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
