Anyone working with the Banks Automind Tuner
$400ish - 4 Tunes, Towing-Sport-Performance-Economy
<LI class=productDetailsTabContentListItem>Equipped with four standard tunes: power, towing, sport and economy<LI class=productDetailsTabContentListItem>Opens the door for customized modding to your rev limited, speed limited, speedometer calibration, cooling fan activation temp, shift points and more
Any good ?
I like the name and the price but can't find any information about the mythical "Other Downloads" they speak of on the Bank's site
Any good ?
Any good ?
Any good ?
Banks Automind tuner
Any good ?
Any good ?
Banks has a reputation of looking at an engine and working to make it more efficient. That was the reason for the larger exhaust for the 7.3. Gail Banks saw that Ford/ International chocked the exhaust down to a small pipe causing the exhaust gasses to add more heat than needed which is an engine killer.
My Banks exhaust, high pressure waste gate, exhaust break, and trans lock were around 4 grand at the time, but the system has held up over the years. The Automind is a performance chip. Mine is an older chip that reacts to the driving style and doesn't have any adjustments outside adapting to my lead foot. Just remember Banks is CARB approved system so you aren't getting anything very wild. Yes performance is increased mileage is increased I run down the highway at around 17 to 18mpg with my set up, if I keep my foot out of it. Exhaust gasses are lowered and the transmission wear and tear are reduced if you get the exhaust break and trans lock, but Banks doesn't program for a super high performance output on your truck. My truck is more powerful and runs better than stock, but it has lasted over the years because it isn't ramped up to push more HP than the engine or trans can take. Banks is a conservative performance mod that is designed to work with smog compliant requirements in any state.
Last time I got smogged they were looking at every non ford part for CARB numbers and they all had them. they even went on line to confirm they were legit.
Depends on what you want to do with your truck. I would start with a 4" exhaust system. it may not add a bunch of HP but it will save your engine and sound cool.
Just keep in mind that Banks has at least two 'minds... the original Ottomind and the subsequent Automind.
The original Ottomind (named after Nicolaus Otto who pioneered the 4-stroke engine) was a module that plugged directly into the manufacturing test port of the PCM's circuit board and stayed physically attached to the PCM, with no operator interaction or adjustments.
The subsequent Automind is a handheld tuning device that plugs into the OBDII port, and has several user selectable "tunes" accessible through a 5 button interface and LCD screen.
diesel-fitter-bum01
29
06-24-2009 11:17 AM
