Extended front brake lines - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-02-2012, 10:03 AM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
what is the best brand, price and seller of extended brake lines?
97 f250 d60 swap with sd v codes and sky mfg 3" rsk
Old 05-02-2012, 12:26 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
I'm not sure but you could PM Evan ( brown falcon ) he just did this not that long ago. Here is his thread
http://www.ford-trucks.com/forums/11...dana-60-a.html
Old 05-02-2012, 01:02 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Crown Performance makes some awesome brake lines, BUT when I tried to run them on my truck, they weren't really even close to fitting at the calipers. The bend in the steel portion of the line was wrong and it hit the calipers and b/c of the way the caliper is cut, the block on the line wouldn't sit flat on the caliper. From what I can tell, all of our calipers are shaped/designed the same, so I'd beware of those lines on our trucks. They have a reputation for not fitting at all on the Broncos, F-150's, and F-250's.
I put those on the shelf and bought some Russel SS lines and they fit A LOT better. They are a little shorter than the Crown lines were, but they will actually bolt up.
Old 05-02-2012, 03:28 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is gaining momentum as a positive member of FTE.BadDogPSD is gaining momentum as a positive member of FTE.
I have the Crown on my truck and didn't have any issues... got them from Caryt @ CT Performance.
Old 05-02-2012, 03:34 PM
Quote:
That's good to hear. They make awesome lines, I've just never gotten a set that fit on my truck.
Old 05-02-2012, 03:51 PM
rat49f6's Avatar
Seems like the russell ones only go up to a 4" lift
With v codes and rsk I think im more than that
Old 05-03-2012, 12:17 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
On mine for now I'm running stock brake lines, but I ran the hard line down below the frame... later on I'm planning on getting stainless braded lines
Old 05-03-2012, 12:35 AM
BadDogPSD's Avatar
Quote:
My truck is a 97, but my D60 is a 94. I originally had purchased Sky Jacker
extended brake lines but didn't like the way they tied into the junction box so I returned them & bought the set from Cary. Guess I got lucky!
Old 05-03-2012, 12:57 AM
I'm running a '94 D60 as well.
Just curious, are the lines then same for the same years F150's and Broncos? Or do you need to get F250 or F350 specific lines?
Also, what are the prices on the Russell and the Crown? Any links?
Old 05-03-2012, 10:11 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
I took my stock lines to a hydraulic shop and had them make new ones but only 6" longer.
It is way better, faster and you can customize the length to what you need.
Plus it is way cheaper than anybody else sells them for.
Jim, You know my truck it has the D60 and RSK with "V" codes also. The lines work great.
Old 05-03-2012, 10:15 AM
rat49f6's Avatar
Awesome thanks neal ill get ahold of the hose man today
Old 05-03-2012, 10:17 AM
gbroehl1's Avatar
gbroehl1 gbroehl1 is offline
gbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to all
You have a "hose man"? Why does that not surprise me. Is that where you do your swim suit shopping as well?
Old 05-03-2012, 10:25 AM
rat49f6's Avatar
Greg ur creepin and I dont appreciate it...
Industrial Hose & Supply, Inc. - Home
Even his shirts say "hose man" on them
Old 05-03-2012, 10:27 AM
gbroehl1's Avatar
Nah, just working from home again today and trying to pass the time while doing as little actual work as possible.
Old 05-03-2012, 11:59 AM
When I talked to the local hydraulic shop they said that they weren't allowed by law to do brake lines because of safety regulations...
Broken brake line early 99 f250 sd 4x4 extended cab caverjoe 1999 to 2016 Super Duty 3 10-16-2015 10:14 PM
Brake Lines Iopoh 1987 - 1996 F150 & Larger F-Series Trucks 1 12-27-2014 07:29 PM
Brake lines and offset rims cuccs58 1987 - 1996 F150 & Larger F-Series Trucks 5 10-07-2014 08:32 PM
Extended front brake lines 77' F250 Crocodile000 1973 - 1979 F-100 & Larger F-Series Trucks 16 07-21-2013 06:32 PM
Extended brake lines Epd444 Offroad & 4x4 2 01-06-2008 04:35 PM
Tags
2004, 4x4, 99, brake, d60, excursion, extended, f250, f350, ford, kit, line, lines, rsk, sky, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
