Extended front brake lines
I'm not sure but you could PM Evan ( brown falcon ) he just did this not that long ago. Here is his thread
https://www.ford-trucks.com/forums/1...dana-60-a.html
Crown Performance makes some awesome brake lines, BUT when I tried to run them on my truck, they weren't really even close to fitting at the calipers. The bend in the steel portion of the line was wrong and it hit the calipers and b/c of the way the caliper is cut, the block on the line wouldn't sit flat on the caliper. From what I can tell, all of our calipers are shaped/designed the same, so I'd beware of those lines on our trucks. They have a reputation for not fitting at all on the Broncos, F-150's, and F-250's.
I put those on the shelf and bought some Russel SS lines and they fit A LOT better. They are a little shorter than the Crown lines were, but they will actually bolt up.
extended brake lines but didn't like the way they tied into the junction box so I returned them & bought the set from Cary. Guess I got lucky!
I took my stock lines to a hydraulic shop and had them make new ones but only 6" longer.
It is way better, faster and you can customize the length to what you need.
Plus it is way cheaper than anybody else sells them for.
Jim, You know my truck it has the D60 and RSK with "V" codes also. The lines work great.
Greg ur creepin and I dont appreciate it...
Industrial Hose & Supply, Inc. - Home
Even his shirts say "hose man" on them
