fuel tank capacity ????? - Ford Truck Enthusiasts Forums
Old 05-02-2012, 09:14 AM
EASTSIDEAUTO EASTSIDEAUTO is offline
EASTSIDEAUTO is starting off with a positive reputation.
1993 F350 crew cab 4x. 7.3l w/banks. I have the dual tanks option on my truck. What is the total fuel capacity? Both tanks were showing empty yesterday but I was only able to put a bit over 26 gallons combined in the 2 of them.
Old 05-02-2012, 09:37 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Each one, I think, should be 19gall. giving 38gall total.
Old 05-02-2012, 10:41 AM
GuitarJesus's Avatar
GuitarJesus GuitarJesus is offline
GuitarJesus is gaining momentum as a positive member of FTE.
You also have a 93, the sending units could be going bad and giving you wrong levels to the gas gauge. Would also help fix the dual tank problems of the non-operational tank getting fuel fed to it, not sure if the diesels have that problem though
Old 05-02-2012, 10:57 AM
Weberman3 Weberman3 is offline
Weberman3 is starting off with a positive reputation.
I think one is 18 and the other is 20 I read once either way its still 38 gallons.
Mine actually shuts off around 20 gallons and the other 23 gallons
Old 05-02-2012, 12:28 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
I have never gotten more then 12 gallons in either tank on my crew cab, although I have never ran either tank completely dry just to find out what they do really hold
My reg cab is a different story, just put 22 gallons in the front tank last nite.....
Old 05-02-2012, 12:30 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
Assuming your truck is a 168" wheelbase (longbed crewcab pickup) you should have 19 gal front & 18 gal rear.
Old 05-02-2012, 12:58 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
That's the same capacities as my SC long bed..
Old 05-02-2012, 02:50 PM
I just noticed the OP has a 350, meaning long bed, so mine doesn't apply...
Fuel tank capacities '95 GoldCo 1987 - 1996 F150 & Larger F-Series Trucks 6 03-12-2016 08:17 PM
Fuel Tank Capacity Truck451 1968-2013 Full Size Vans 2 05-09-2010 02:44 AM
fuel tank capacity mudslinging79 Bronco II 4 09-30-2009 08:41 PM
Gas tank capacity ttexastim 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 01-21-2009 11:51 PM
96 F150 -- Capacity of Twin Fuel Tanks akbar 1987 - 1996 F150 & Larger F-Series Trucks 20 03-31-2002 10:47 PM
Tags
1993, 1997, 93, 96, capacity, diesel, dual, f350, ford, gas, rear, size, tank, truck, volume
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
