2000 F150 Instrument Cluster - Ford Truck Enthusiasts Forums
Old 05-01-2012, 06:45 PM
hetman hetman is offline
hetman is starting off with a positive reputation.
Hello everyone, just signed up! I have this old but great 2000 f150, gave it to my girlfriend to drive since her car died. Problem is that the gas gauge is broken, so it always sits on empty. I'm always worried she will run out of gas somewhere and it will be a headache for me, because even though the "low fuel" light still works, she can be a bit of an airhead so I can't rely on her seeing it in time to get to a gas station. At any rate, theres an instrument cluster for sale that I saw that is fully functional from the description. Its like 50 bucks (totally worth it imo) but the seller claims that it has some kind of immobilizer and that it needs to be programmed to work. I don't think my truck has any kind of immobilizer to my knowledge, so my question is what exactly is this immobilizer and why is it in the instrument cluster? What would happen if I just swap this functional cluster into my truck? What would work and what wouldn't?
The seller also said that I might have to take it to a dealer to have it programmed, which imo is never a good idea since any visit to the stealership always costs quite a bit...
Any help would be great guys!
Old 05-01-2012, 08:24 PM
Come to think of it, is the seller referring to the anti-theft light?? I can care less if that's what it is, I will just find a way to make the light stay off
Old 05-01-2012, 08:36 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Your at a lack of information.
The truck likely has an anti theft system called PATS.
These systems 'marry' by code to the PCM.
You cannot replace either one with out a reprogram by a dealer.
Also the keys have to be reprogrammed.
The system was design to be nearly fool proof such that you cannot work around it.
As to the fuel level gage, a look a the DTC HEC code may tell what the situation is.
Could be the dash, could be the sender on the fuel pump or harness in between.
Sorry you would like it to be easier but welcome to the computer world.
It won't get better any time soon.
If the dash diagnostics can be accessed, step to the fuel data readout and see what the value is. The number is a decimal readout to an Octal number base.
Readings are 0 to 18 is a short (a fault)..
54 is low fuel, 41 is E mark.
93 is 1/4 tank.
138 is 1/2 tank.
178 is 3/5 tank.
215 is full tank.
255 is an open sender (a fault).
To access the dasd diagnostics, push the reset **** in and hold.
Turn on the ignition swoitch to RUN while holding the reset in for about 5 seconds then step through the sequence using the rest until you get to the fuel readout, and note the value.
If this works, you can see the fuel level anytime without the gage working but not on a continious basis.
I think you can see by now that in this day and age, the systems have to be looked at in this manner or you have no idea what is going on.
Dealers techs have to do it the same way.
The designers gave thses ways to look into the systems so they have to be used.
Good luck.
Old 05-01-2012, 09:51 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
normally when the gas gauge dont work, the gage is not the problme. Sending unit it tank or bad wire connection at tank.
Old 05-02-2012, 07:43 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
If the LOW FUEL lamp works PROPERLY, the fuel tank sender is fine and it's just a busted gauge.
Old 05-02-2012, 11:09 AM
So if I did get this functional cluster into the truck, I wouldn't even be able to start it or anything without a dealer reprogramming?
Old 05-02-2012, 05:44 PM
That's right, unless you also get the original PATS keys that went with that cluster and know how to "cheat".
instrument cluver Manu 6.7L Power Stroke Diesel 4 08-09-2016 11:10 PM
Instrument cluster interchangeability...? 12valveEx 1987 - 1996 F150 & Larger F-Series Trucks 1 08-02-2015 09:07 PM
Reprogramming a 3 button key fob. Calixto 1997 - 2003 F150 3 11-09-2014 02:09 AM
Replacing Instrument panel bulbs, requires reprogramming?? pjw73nh Explorer, Sport Trac, Mountaineer & Aviator 0 04-22-2013 09:41 AM
Manitoba & immobilizers jagabom Manitoba / Saskatchewan Chapter 15 09-13-2010 02:12 PM
Tags
03, 2000, 2002, alternate, cluster, dash, f150, gauge, guage, heats, instrument, panel, questions, removal, reprogramming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
