05 Expedition Broken Vacuum Line Question
I have spent several hrs on here looking for the possible answer to my question. It seems this is a common problem. A/C will only blow thru defrost vents. This happened to me the other day. So today I checked under the hood and found this...see pic. I have the probable answer, break in the vacuum line. My problem is I have no idea where the other end of this line is supposed to go. Any help would be appreciated. Pics would be fantastic.
i figured out my problem, here was my solution in case it helps anyone else out.
on the firewall passenger side where the gray vacuum tube runs into the firewall grommet there is also another hole for the black vacuum tube( my pic ) in the same grommet. since my black tube had fallen completely out of of the firewall grommet i couldnt tell were the end of my mystery vacuum line went from my pic. after enough poking and searching i finally saw the other empty hole in the firewall grommet. it was nicely hidden by some gunk build up. i pulled out the grommet, which was actually a mistake because the grommet has 2 connectors built into it. when you remove it, it pops the tubes off from the inside of the firewall since there isnt that much slack in them. and if you have big hands it gets alittle tricky to get them back on so use caution. once i plugged everything back up, grey and black tubing the a/c works fine out of the vents correctly.
05 Expedition Vacuum line
"I have spent several hrs on here looking for the possible answer to my question. It seems this is a common problem. A/C will only blow thru defrost vents. This happened to me the other day. So today I checked under the hood and found this...see pic. I have the probable answer, break in the vacuum line. My problem is I have no idea where the other end of this line is supposed to go. Any help would be appreciated. Pics would be fantastic."
I have the same issue. Where does the gray vacuum line connects to? Does the black vacuum line connects to the one located at the firewall? Your answer is appreciated.
The small black line feeds TO the climate control system, so it should be going INTO the firewall from the engine bay. The grey slightly fatter line feeds to the hot water control valve there in the heater hose line of the engine bay. I would assume you're having all kinds of climate control issues as well.
-Mike
You should see the grey vacuum line plugged into the hot water valve here....
Take a LED flashlight and look on the firewall right in that area, you should see a pair of vacuum lines like this .... small black one, and fatter grey one....
-Mike
vacuum Line
The Grey line goes to the hot water control valve. Look at the pics I posted. Somebody butchered your setup.
Yes, the black line goes to that pancake looking check valve fitting you are pointing at. You'll have to get some vacuum tubing to make up the connections.
Nothing goes on that other white line plug, it should just be there to seal the line, it should be sealed if it is not already. Put a cap on it to seal it.
There should be no vacuum leaks in any of the lines under the hood !
Who the hell's been under the hood of your truck ?
-Mike
