05 Expedition Broken Vacuum Line Question - Page 2 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-26-2014, 10:59 PM
LionHeart22 LionHeart22 is offline
LionHeart22 is starting off with a positive reputation.
Thank you Hamfisted. I took it to one of the Ford dealership here in Renton WA to have the a/c check. I did not have them fix it because it will cost arms and legs. To make the story short, after a week when I tried to use the heater and try to change the direction of the air flow, it only blows from the defroster. When I opened the hood, I noticed these two lines been cut. I never trusted that place afterward or any shop for that matter.
Old 02-27-2014, 12:31 AM
lawdog1973 lawdog1973 is offline
lawdog1973 is starting off with a positive reputation.
I am having same issue my email is clayaustin30@gmail.com. I think I have the same lines broke.
Old 02-27-2014, 08:39 AM
I'm having the same issue can you guys take a pic of more from the top and closer to the fender? I think someone has butchered mine as we'll and I'd like to see what it is supposed to look like. There is a valve further back with two vacuum fittings and an electrical fitting. My he is also stuck on defrost but I don't want to disconnect other lines and have something else not work.
Thanks
Old 02-27-2014, 11:16 AM
Hamfisted Hamfisted is offline
Hamfisted is starting off with a positive reputation.
Quote:
What was the original problem with the A/C system ? If it was a vent directional problem the lines were probably already broken off. Without that black vacuum line attached you will have nothing but defrost. Without the grey line attached you will have no heat.
Lawdog take/post a pic of your truck under the hood of the area you are interested in...
-Mike
Old 02-27-2014, 01:37 PM
I can't figure out how to attach photo from my iPad. My issue is my heat is stuck on defrost I have the same broken vacuum line but where you are saying to attach the broken line already has something hooked to it as well as the white T that is supposed to be a dead end or block.
Clay
Old 02-27-2014, 04:47 PM
Quote:
Clay
You need to make a Photobucket account and upload pics there then just copy the link and post it here. It's really hard to troubleshoot stuff like vacuum lines without pics of what you're talking about. But anyway here's a wider field of view of that area.
-Mike
Old 02-28-2014, 11:05 AM
OK I think I got that problem fixed. I found another broken vacuum line right next to the abs sensor and lf back 2 valve cover any ideas? I'm also getting the dreaded P0345 and 349 codes. And I still can't figure out how to download pics.
Old 02-28-2014, 04:18 PM
I go the line to their supposed connection but the air only flows from the defrost still. Any more suggestion?
Old 02-28-2014, 04:22 PM
I had to block off that T connection Ur was not a closed circuit I put a little spit on the end and it sucked it right up. I capped it and everything worked.
Old 02-28-2014, 04:24 PM
I'll try that it. Thanks
Old 02-28-2014, 05:15 PM
Still the same. Do you a picture of how your lines are set up from the firewall to to where they are suppose to be connected? I looked at an '01 and '03 and it's different from my '05. Thanks
Old 03-11-2014, 09:12 AM
jbedsole23 jbedsole23 is offline
jbedsole23 is starting off with a positive reputation.
Quote:
Originally Posted by bigbswa View Post
I have spent several hrs on here looking for the possible answer to my question. It seems this is a common problem. A/C will only blow thru defrost vents. This happened to me the other day. So today I checked under the hood and found this...see pic. I have the probable answer, break in the vacuum line. My problem is I have no idea where the other end of this line is supposed to go. Any help would be appreciated. Pics would be fantastic.
Do you have any idea what line size it is to splice the broken line back together. Mine is not totally broken but it is definitely cut. Any suggestions on where to find the parts?
  #28
Old 03-11-2014, 09:16 AM
Quote:
Your local checkers should have a section of just vacuum stuff. I bought hose and spliced into mine. It works great. The pos 5.4 is another story. First and last ford I'll ever buy.
  #29
Old 03-11-2014, 09:19 AM
Quote:
Originally Posted by Hamfisted View Post
The Grey line goes to the hot water control valve. Look at the pics I posted. Somebody butchered your setup.
Yes, the black line goes to that pancake looking check valve fitting you are pointing at. You'll have to get some vacuum tubing to make up the connections.
Nothing goes on that other white line plug, it should just be there to seal the line, it should be sealed if it is not already. Put a cap on it to seal it.
There should be no vacuum leaks in any of the lines under the hood !
Who the hell's been under the hood of your truck ?
-Mike
Any idea of the vacuum line size or how to splice those back together if they are cut?
  #30
Old 03-11-2014, 09:21 AM
I cut mine took a piece down there and found it. I put zip ties around both ends I know it cheesy but it worked.
C6 Vacuum Modulator Line e30rik 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 08-27-2016 07:30 PM
Ported Vacuum Switch for Vacuum Advance? Ford59galaxie 1973 - 1979 F-100 & Larger F-Series Trucks 21 02-12-2016 06:29 PM
54 F-100 Vacuum System-Wipers and Brakes Michael Levy 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 12-17-2014 08:41 PM
Vacuum Line Replacement The Terrible Blob 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 03-10-2014 11:56 AM
Vacuum line question 78 & 87 Super Cab 1987 - 1996 F150 & Larger F-Series Trucks 3 11-07-2013 01:44 PM
Tags
06, ac, black, broken, expedition, firewall, ford, grey, grommets, lincoln, line, lines, navigator, transmission, vacum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
