wrench light on dash came on - Ford Truck Enthusiasts Forums
Old 05-01-2012, 06:00 PM
paddler65 paddler65 is offline
paddler65 is starting off with a positive reputation.
the wrench light on the dash came on and i was told that the truck was ready to go into limp mode. i recycled the key and the light has stayed off for four months. pulling back from fl. the light came on again and i recyled the key and the light has stayed off. i'm prepairing for a long trip anf trying to get every thing correct.
any one have this problem? what can cause the wrench light to come on. i just changed the fuel filters and cleaned the egr valve. i did get about 1 tsp. of water out when the rail filter was changed.
thanks
Old 05-01-2012, 06:51 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
need a scan tool to pull codes. most will not pull wrench light related dtc's however I know an ids will
Old 05-01-2012, 06:59 PM
Quote:
i dont have a scan tool. i was trying to save the 105.00 cost to the dealer.
thanks.
Old 05-01-2012, 07:18 PM
Mich6.0 Mich6.0 is offline
Mich6.0 is starting off with a positive reputation.
Both times were you pulling and if so could be the warning light for eot/ect might have the flash for oil cooler failling warning
Old 05-01-2012, 07:19 PM
cheezit's Avatar
oil cooler or boost issues.
Old 05-01-2012, 07:48 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
thanks.
That 105 could be cheap you keep playing russian roulette with a wrench light. Just the tow charge could cost more than that.
Old 05-02-2012, 08:40 AM
i tow a 5ver over 13k lbs. both times the wrench light came on was after towing about 100 miles into the trip. both times after recyleing the key the light stayed off for the next 600 mi. the service tech said if it was an oil cooler it would go out and stay out. im going to the dealer in the morning. will keep you posted.
thanks
Old 05-03-2012, 06:09 PM
well go figure. the wrench light is a ghost. took the truck to the dealer and no codes showed up. the wrench light has been on two times and there is no trail of a code. anyway i'm happy. thanks for your help.
Old 05-03-2012, 09:47 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
Once I got a Wrench Light while pulling uphill and it went in Limp Mod. But it went off for many thousand miles without a light. I look at it this way, this is a computer, it has it's bogs and it receive many info from many sensors.
Old 05-05-2012, 01:23 PM
Quote:
good to hear from some one that went into limp mode and the truck was still useable for that long. i will be less concerned.
i got 91k on truck and the engine has been out two times. the truck had a bed plat leak, blown head gaskets, i replaced the air condition compressor, rear brakes and last year i had three injectors replaced. about time for this truck to fine some else to keep it moving.
Old 05-05-2012, 03:12 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Under certain conditions that set the wrench light, it is possible that an engine can generate all kinds of soot (and even heat). I would hate to have that potential issue "hanging over my head" - especially on long trips.
When was the last time you had it flashed? I assume it is not tuned?
Old 05-05-2012, 07:30 PM
atomicglock atomicglock is offline
atomicglock is starting off with a positive reputation.
This happened to me a couple months ago while trying to pass some traffic on an uphill grade. Took my truck to the dealer and they told me they had to re-flash the computer. Must've worked because the wrench light has not come back on since.
Old 05-06-2012, 03:10 PM
Quote:
the truck was reflashed last year before the injectors were replaced. the service advisior had said any time a light came on it would leave a foot print. nothing was reported on the test and i dont understand why nothing showed up on the test.
i will keep the reflashing in mind if i have trouble this summer. i hate to think that i might go into limp mode going thru a large city.
just thinking -i have always cleaned the EGR valve rather than replacing the valve.
thanks
Old 05-06-2012, 04:15 PM
MAD MAD is offline
MAD is starting off with a positive reputation.
oil cooler, had the same problem last summer, caused the egr cooler to fail, also head gaskets. I would get it checked out before you pull anything for any distance.
Old 05-06-2012, 05:12 PM
firedaniel firedaniel is offline
firedaniel is gaining momentum as a positive member of FTE.
I agree mine had the same issue. Got a scan guage to verify and watch the EOT/ECT and saw it. Replaced the oil cooler and deleted the EGR no more wrench light...
2008 F250 6.4l no crank no start after water in fuel moctx 6.4L Power Stroke Diesel 6 12-10-2015 11:10 AM
water separator and wrench light on? SUPERDUTY_08 6.4L Power Stroke Diesel 11 03-08-2015 10:15 PM
wrench light no code ldj 6.0L Power Stroke Diesel 10 10-01-2013 03:03 PM
wrench light paddler65 1999 to 2016 Super Duty 8 05-17-2012 08:35 AM
Fuel filter change no start Rudiak 6.4L Power Stroke Diesel 16 01-10-2011 04:35 PM
Tags
2006, 250, 60, air, dash, diesel, f150, f250, filter, ford, light, truck, weench, wet, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
