Autolite Carb
Old 05-02-2003, 02:01 PM
gonefishin's Avatar
gonefishin
gonefishin is offline
Question Autolite Carb
I've got an Autolite carb and I am trying to figure out the CFM rating. The numbers are C8TF AE and A7L24 at the bottom of the tag. My goal is optimum mileage. Would it be better to keep this carb or go with something else?
Old 05-03-2003, 12:12 PM
Chas1234's Avatar
Chas1234
Chas1234 is offline
Autolite Carb
What is the number on the side of the float bowl ?
There should be a number like 1.21 on the side where the excellerator pump rod is .
Post that number and I can tell you the cfm!
Old 05-03-2003, 05:22 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Autolite Carb
There is a star or circle right behind the rod for the accelerator pump. The number inside the mark corresponds to the cfm rating of the carb.
Old 05-04-2003, 07:07 PM
gonefishin's Avatar
gonefishin
Autolite Carb
The number on the side of the carb is 1.23
Old 05-04-2003, 07:26 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Autolite Carb
Ok, that would make it a 356cfm carb. This is a pretty good starting point for a mileage carb. You could trade up to a 500cfm Holley 2BBL, but they do tend to run rich. This carb, freshly rebuilt, and properly adjusted, should do the job.
Old 05-05-2003, 09:57 AM
gonefishin's Avatar
gonefishin
Autolite Carb
Would the Holley 500 cfm 2bbl give the same mileage and better power gains, of course without my foot to the floor, with normal driving? Also, the 356 cfm carb is fairly common if I remember correctly. Will just about any 356 cfm carb work for me, because I would like to find one with an auto choke.
Old 05-05-2003, 11:23 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Autolite Carb
The 350cfm is pretty common- I don't know if the 500 will give you better mileage. Like I said, Holleys tend to run rich, so it may decrease your mileage.
Nick-1973-ford
07-09-2016 09:25 AM
hooler1
01-16-2016 08:52 PM
53rmod
12-03-2015 08:55 PM
jzzzake
06-20-2015 10:43 AM
46yblock
13
06-07-2008 02:42 AM
Quick Reply: Autolite Carb
