KY Chapter Members Map
#31
John I have a garage but it might be a tight squeeze. You have seen Paul's truck before is it lifted? I have a garage at the apt complex I live in and put the Trailblazer in it with ease. albeit a trailblazer is not as big as a f250. If you are in the florence area this week give me a call and I will let you be the judge if it could work.
So yes I am offering the use of my garage to you or anyone really who is local. I have some tools and more over at my dads house that I still need to bring over... just got the garage earlier this year and haven't brought them over. If you need something special you might have to bring it.
#32
John depending on when and where I might be able to assist in some sort. If Paul brings his truck up here I wouldn't mind helping if I can. Don't know too much about diesels but I will help any way I can plus I might learn a thing or two.
Cody that sucks about your transmission. Are you having one built that can take all your upgrades?
#33
Not it is one of Ford's Better Ideas. Run lines through an area that you cannot wash out. The line just corroded and burst. The brakes were typical before. I do need to turn all of the rotors, level the pads and grease the pins. Last I looked, the pads looked new. I have no idea what the vibration is in the front, it could be a wheel bearing to the CV joint. It is on the right side.
#34
Let me know when you are up for a BS session... Planning on being there Saturday from Noon-8ish and Sunday Noon to 6ish. Have refrigerator full of beers... and a good amount of tools... I would be up for a meetup someplace central too, I am thinking it would not be great to have 20 peeps show up at my place, but 1-4 tops would probably work..
my email is goliath2002@yahoo.com ... and it is linked to my phone so I should get it if I have some down time.
#37
#39
You are signed up as a Ky Chapter member. If you are not listed in the map that Wes (sidewinder4.9l) set up, you have to do that yourself, or, I believe Wes can set you up with that. I am not knowledgeable enough to be able to do that.
#40
#45
