1996 ford f150 300 6 cyl - Ford Truck Enthusiasts Forums
Old 05-01-2012, 11:49 AM
Big Cuz Big Cuz is offline
Big Cuz is starting off with a positive reputation.
Okay long story short..My front tank fuel pump quit working. So I switched to my back tank and now my truck wont run right..Its will start. But it it has no power and no RPMs..It just spit and sputters again with no power..Any help will be greatly appreciated
Old 05-01-2012, 01:15 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Rear pump could be failing, or have a plugged filter sock. If the front fuel pump module has failed, the rear pump can be pumping fuel into the front tank, starving the engine.
Old 05-01-2012, 01:48 PM
882tank's Avatar
882tank 882tank is offline
882tank is starting off with a positive reputation.
Time for a new pump and filters. Do a search. There are lots of threads on this. Good luck and welcome to FTE.
95 f250 runs crappy on from tank Manaze450 1987 - 1996 F150 & Larger F-Series Trucks 5 07-12-2016 08:52 PM
Fuel tank issue 264WSM Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-25-2015 08:54 PM
bypass tank selector switch? JHAM 1987 - 1996 F150 & Larger F-Series Trucks 3 01-27-2011 10:05 PM
7.3 Diesel Fuel Tank Sucking Air When The Tank Is Below 1/4 Tank SAUER Excursion - King of SUVs 3 12-13-2003 06:06 PM
no power to either fuel pump w/ dual tanks 89 460 f-350 joeohio37 1987 - 1996 F150 & Larger F-Series Trucks 5 10-02-2003 07:14 AM
Tags
1996, 3006, 385, 96, bauer, buy, code, cylinder, eddie, f150, ford, forums, northern, sale, va
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
