header of exhaust manifold - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-01-2012, 11:40 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
my Gibson header gaskets are leaking causing my motor to have a tick, so i have to buy ARP stainless header studs some time this week and new gaskets. Gaskets are 20 bucks, new studs are 160 bucks.... so my question is do i reuse my gibson headers that cant be torqued to spec because the pipes are in the way and you can ONLY use a box wrench OR install my original exhaust manifolds that only have 21k on them and are level and not worped that CAN be torqued to the proper 35ftlbs? I just dont want to rip it all apart again in five years and do this all over again?
Old 05-01-2012, 05:41 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Are you sure you can't torque them with a crows foot or swivel extension?
Old 05-01-2012, 08:21 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I never torqued header bolts/studs on a any truck I had. I tightened them all by hand on every truck I have. The OE manifolds for the 2Vs are garbage I wouldn't go back to them for any reason.
Old 05-01-2012, 11:35 PM
Gastic3514's Avatar
Gastic3514 Gastic3514 is offline
Gastic3514 is starting off with a positive reputation.
Use dead soft copper exhaust manifold gaskets. A few companies make them. (hopefully for the Mod Ford motors too). I have been using them on my race car for several years, 0-problems. They were recommended to me by a racer / engine builder buddy.
They WILL NOT blow out.
Old 05-02-2012, 07:30 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Have had a few different headers and gaskets on a few different vehicles.
Number one thing to do is TIGHTEN and TIGHTEN those header bolts. The gaskets crush over time, and in the first few months of service, the bolts need to be retightened every change you get.
I do it just about every other cold-warm-cold cycle for the two weeks, and then check them for the next few months. And then again, every oil change.
I always find they get somewhat loose for the first 6 months to a year and then they're good.
Old 05-02-2012, 10:09 AM
when i installed them five years ago i checked them once a week, eventually they got tight and stayed that way. Then i checked them monthly ans so on, then ever once in a while. For some reason one blew i think cuz i have a tick now and i checke everything else, i have all my factory nuts still and studs and even though they are a little rusty they are all still there and tight! Guess ill just have to replace the gasket and studs and SEE if the tick goes away
Old 05-02-2012, 11:00 AM
dkf's Avatar
dkf dkf is offline
Just make sure one of the welds or tubes on the headers did't crack. Its not common on a good set of headers but it can happen.
Old 05-02-2012, 01:16 PM
Krewat's Avatar
dkf is right, check for cracks...
And, is the tick only when you step on the gas, or all the time?
Old 05-03-2012, 09:12 AM
actually its very odd tick, weather has been crazy lately here in NJ some days it goes to 80 degrees and other its about 50 degrees. Anyway it does it at idle almost all the time and when i drive down the street i cant hear it at all. Some days it does it right away when i start the truck and other days it doesnt do it untill the truck is fully warmed up?
Old 05-03-2012, 09:14 AM
when i checked the studs the other day i looked around the header tubes and i didnt see any cracks or soot blowby anywhere, but where the pipe is bent up to the flange there is alot of rust on the stainless? It could be rotted through but Gibson headers are suppose to be good quality stainless so....
Old 05-03-2012, 10:54 AM
dkf's Avatar
dkf dkf is offline
Your Gibsons are probably 409 stainless which will rust but is rust resistant.
When my headers were put on there was a slight tick that you only really heard at idle. I tracked it down to a crack in the gasket on a corner of the header. Turns out the tech creased the gasket during install and caused the slight leak. Replaced the gasket and it fixed the problem. Some gaskets are pretty fragile and it can be hard to install them in tight places without damage.
Old 05-04-2012, 05:51 PM
thanks DKF
ordered exhaust studs and new gaskets(now have new tick 6-6-12!) SuperDutyScaler 1999 to 2016 Super Duty 25 10-25-2012 07:33 PM
Exhaust questions for 460 V8 Motorhome TallPaul Exhaust Systems 12 06-04-2012 06:36 PM
JBA or Gibson Headers? BigDawg54 Exhaust Systems 10 08-09-2008 01:47 PM
For Those of You with Gibson Headers Studenut65 Modular V10 (6.8l) 25 04-16-2006 04:32 PM
5.4 headers 02mudbug 1999 to 2016 Super Duty 17 02-20-2006 01:50 PM
Tags
exhaust, ford, gibson, good, headers, manifold, pipe, springs, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
