A/C compressor Died - Ford Techs come in here - Page 2 - Ford Truck Enthusiasts Forums
Old 05-21-2012, 06:53 PM
96_F250_Deezal 96_F250_Deezal is offline
96_F250_Deezal is gaining momentum as a positive member of FTE.96_F250_Deezal is gaining momentum as a positive member of FTE.
$335 for compressor, dryer, orifice tube and belt. $242 for new fan stator.
Old 08-04-2015, 03:30 AM
mario1987 mario1987 is offline
mario1987 is starting off with a positive reputation.
here is a question, i want to put auxiliary air on my truck, i dont have a/c and was wondering if i buy a a/c compressor can it be plumbed to fill a tank for my air bag helpers?
Old 08-04-2015, 03:51 AM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.
Quote:
You should start your own thread for "on board air " and do a search.
You can use an a/c compressor but to make it last you need to run an oil separator with a drain plumbed back in to the suction side of the compressor. The reason being is to recharge the compressor with some PAG oil or the compressor won't live long. I have an elaborate system on my rock crawler samurai that bumps up the throttle and turns off @ 150psi. plumbed into a 6 gallon tank using a stock A/C compressor and pressure switch. You can find plenty of info and parts here: ::Kilby Enterprises::
Old 08-04-2015, 08:09 AM
Appreciate the info I just didn't know where to start as far as if it could be done and if it weighs out the cost I'll just get an onboard air compressor system kit
Old 08-04-2015, 08:25 AM
For just air bags it's probably to much work and money. I run air ratchet and air impact guns off of my system for trail repairs.
Sounds like you'd be fine with a Viair compressor. http://www.amazon.com/gp/aw/d/B000X9...-zL&ref=plSrch
'08 constant electrical draw A/C Clutch fuse location interstategar 1968-2013 Full Size Vans 3 11-02-2016 10:43 PM
What A/C compressors will work? 1988F1504x2 Ford Inline Six, 200, 250, 4.9L / 300 1 12-29-2015 12:19 PM
A/C compressor won't start CNGBuff Cooling, Heating, Ventilation & A/C 14 08-31-2015 08:06 AM
Please help me with my custom A/C sittinlow88 1967 - 1972 F-100 & Larger F-Series Trucks 3 04-05-2015 11:41 PM
A/c compressor keeps running and no heat tengel 1999 to 2016 Super Duty 1 10-11-2004 03:10 PM
Tags
2004, 60, ac, charge, compressor, cost, diesel, f250, ford, proper, remove, removel, shop, time, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
