08-12 Crew Cab Front Seats Into Excursion
Question
Builtfordtough!, I have a coupe of questions (im in snohomish so if texting would be easier let me know).
1) Do you still have the pic of the control box and wiring removal? Looks like it got removed off your thread.
I just got leather seats out of a 2008 Lariat (Power & Heat). I am assuming they have memory hence the reason to rip out the control box.
I cant find a wiring diagram of wiring harness you listed, but im assuming when you talk about removing the existing harness and control box this new harness will be literally a plug and play into where the old wires were (Basically this harness removes the control box?).
2) So verifying the Drivers side pin routing. I have a current plug (3 wires in a 4 wire plug, Seatbelt, power and ground) under my seat for seat belt (Pin2), power (Pin1) and ground (Pin5&6). I get Pin 7&8 go to the new heated switch, but where did you tie in Pins 3&4. Did you just tie them all in to the existing Power (Pin1). None of the wires on your schematic are Keyed on power. Is that correct or am I missing something?
Stewart
I saw an extended cab Lariat F250 the other day with searbelts on the pillars. Looked to be a 1999-2004 based on the grille.
Unless the seatbelts come out of the side of the seats rather than the backrest.
My old '02 SuperCab F250 had the seat belts in the seat back. The seat belts were set up like this:
So if the newer trucks kept the same setup, there would be this difference.
Stewart
Thread bump... Any issues with plastic trim color matching on models with beige plastics? I so want to find some seats for my '05 limited now, as I can't stand the placement of the armrests on the factory seats! Also, please make more clear the wiring as mentioned by others here... thanks, and they look great!
-shannon
-shannon
-shannon
#28
I think you are trying to say "Also, I understand that you have done all the hard work and put your money into finding out if it would work or not but if you could give a few more details about the wiring I would really appreciate it. Thanks in advance for the help, please don't think I'm being demanding."
Is that about right?
#30
I keep finding good deals on KR seats ($1500 including the console) but every time it turns out it's for a damn f-150!!! It pisses me off they did that version, kind of defeats the purpose IMO
