You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My 08 Edge has a factory installed hitch, so I can't foresee any problems to put one on your MKX. The factory hitch is a light duty 1.25 inch square receiver, not the std heavy duty 2 inch square. You could probably do it with factory parts, check some junkyards.
__________________
1949 F-6 COE hot rod
1988 F-250 4x4 7.3 5-speed ATS
1937 Ford Utility Coupe (Ute) hot rod
Other old non-Ford trucks and cars
If you are handy with tools, you should be able to find a hitch on the internet from Reese or another provider that you can install youself. For the lights its easiest to take the vehicle to a U-Haul Hitch installation center and let them do it as they will have it done in the time it takes for you to read the wiring directions.
I have never looked at the factory wiring. For many vehicles you can buy a trailer wiring adapter. It usually plugs into the wiring harness at the rear and provides a tee that has the wires for the trailer plug. No idea if one available for the Edge or not.
To be honest I have not used the Edge for any towing. I have full size trucks when i want to tow a trailer.
__________________
