Low oil pressure when engine is hot - Ford Truck Enthusiasts Forums
Old 05-01-2012, 02:32 AM
andrewscofield's Avatar
andrewscofield andrewscofield is offline
andrewscofield is starting off with a positive reputation.
So, first time posting, been browsing for a couple months now! TONS of great, knowledgable people on here, I'm stumped on my current issue.
A couple months ago I bought 1973 F250 with a rebuilt 390 and it runs great, only 30k miles on rebuild. I use it as my daily driver. I've had a couple electrical problems that were easily fixed, other than that just flushing fluids and replacing filters.
Now, the weather is starting to warm up and I'm now seeing a new problem. I have an aftermarket oil pressure gauge installed by the previous owner. When I start my drive oil pressure is great, as the engine warms up the oil pressure drops but ONLY if I am idling. As soon as I hit the gas pedal, it goes right back up to normal level.
So my question is, since the car is running great, no strange sounds or knocking, is this a normal/ok behavior or a sign of something bad? Thanks,
Andrew
Old 05-01-2012, 05:41 AM
OldStyle's Avatar
OldStyle OldStyle is offline
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
Here is a post that contains the info/fix you need. It's just the design.... No worries!
Link: http://www.ford-trucks.com/forums/11...-in-390fe.html
Old 05-01-2012, 08:44 AM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
How low does it drop? My 360 with roughly 15k miles on a rebuild idles at about 12-15psi hot, the instant the rpms come up it rises, cruises at 55-60 psi.
Old 05-01-2012, 11:11 AM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
That's normal for the oil pressure to fluctuate with ambient/engine temps and rpms, my 390FE with 40K on a rebuild reads 20psi @hot idle (800rpm) and 60psi @cruise (2,500rpm).
Old 05-01-2012, 07:41 PM
999yards 999yards is offline
999yards is starting off with a positive reputation.
I may have a problem then. I just noticed my oil psi is at 60 at start up. When then engine warms up it goes down to 40 and stays there no matter what the rpm's.
Is that trash in the oil pick up? I did notice that its time for an oil change, it pretty black and getting thin feeling.
Old 05-01-2012, 07:43 PM
bamaf150's Avatar
Quote:
Mine had those same numbers with 15w-40w, a little lower with 10w-30w, what viscosity are you using out of curiosity?
Old 05-01-2012, 08:09 PM
Quote:
Bama, those numbers are running 15w-40 (Rotella).
Old 05-01-2012, 08:54 PM
bamaf150's Avatar
I use Rotella too and next change will use 15w-40, summers here almost.
Old 05-02-2012, 02:34 AM
Evan's F250's Avatar
Evan's F250 Evan's F250 is offline
Evan's F250 is starting off with a positive reputation.
If its getting that good of oil psi, you're fine. Be happy. Most engines I've had run 15-20 psi hot in gear idling. If the oil seems worn, change it. Use some 15w-40.
Old 05-02-2012, 10:33 PM
jeff14346 jeff14346 is offline
jeff14346 is starting off with a positive reputation.
my 390 has about 400 miles on it since rebuild, cold psi cruising is 55-65psi
cold idle 20 psi
warmed up in gear 4psi, put in nuetral and goes to about 9psi, no noise, no issues clean oil, jump right back up at touch of throttle
using melling high volumn pump, also have the holley jets in oil passage to help slow flow to upper end, crank is turned .010/.010 on mains and rods
Old 05-03-2012, 02:44 AM
Well, thats good news, sounds like this is not a problem. With the engine warm I am getting between 30-35 while accelerating and around 10-15 while idle.
It was just kinda messin with me because the needle moves up and down so fast, I wasn't sure if it was a problem or not.
Thanks everybody
0 oil pressure at idle and metal shavings on drain plug Dcnnnghm 1999 - 2003 7.3L Power Stroke Diesel 10 04-04-2016 06:35 PM
And it continues... John Irwin 6.0L Power Stroke Diesel 6 10-10-2014 01:06 PM
What is "Good" oil PSI for a 6.9??? Ford F834 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 02-15-2011 03:45 PM
More Oil Pressure Problems bigmike33 6.0L Power Stroke Diesel 18 01-02-2010 06:17 PM
oil pressure gauge fluctuating..2001 facial 1997 - 2003 F150 8 11-27-2008 08:43 AM
Tags
2008, 64, drop, engine, f150, f250, fe, fluctuation, hot, low, oil, pressure, truck, warm, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
