Chrome step bumper for a narrow frame
The painted bumper you have is correct, the chrome bumper isn't and neither are the brackets.
If you want to use it anyway the solution is easy I've done it both going wider and narrower. simply use your original brackets and find the width spacer material you need and make a pair. drill the holes and get longer bolts and you have it. if you want to use the outer braces you'll have to modify them which is also easy.
John R. Thomas
10-08-2019 08:56 PM
John R. Thomas
10-04-2019 08:42 AM
John R. Thomas
07-27-2019 09:38 PM
filthy6
02-26-2014 09:16 PM
