You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a industrial 460 laying around with a crank that is not designed to take an auto transmission, so the pilot bearing in the crank won't accept a standard C6 torque converter bearing. The question that I have, is would I be able to mate a T18 4sp to the engine? Does a t18 have a pilot bearing like a c6 does?
Thanks
Jameson
__________________
Summer Project: 1971 VW Baja 1600DP
Driver: 1987 F250 super cab/long bed 6.9/ZF5/2wd, 3.55 LS Sterling 10.25 rear
Project: 1979 F250 super cab/long bed built 460/Stage 2 shift kit C6/2wd, 4.10 open D60 rear
Quote:
What Jameson has done, is buy another hole in the space/time continuum that will consume money and time, yet take up space. A true modern conundrum of Physics
Yes, you have a pilot for a manual trans. There are two sizes of AT crank pilots for those motors. Could that be your AT problem? What size is the hole in the back of the crank?
iirc, there are 1 3/8 and 1 7/8 inch pilot bearings for standard c6 tc. The bearing hole in the rear of the crank is about 3/4 to 7/8 inch
as for accepting a trans, it has the right bolt pattern for a flywheel/flexplate, and a trans bolt pattern on the block. The crack is the 460 stroke version of the 370 industrial crank, which was used in busses and other large vehicles
