1998 navigator upper control arms ball joints - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-01-2012, 12:46 AM
a lincoln or two a lincoln or two is offline
a lincoln or two is starting off with a positive reputation.
hi everyone,
ok so i need to upper control arms w/ball joints the job looks super easy however, finding replacement arms with air ride is proving to be a bitch.
so what have you guys done to keep the height sensors on the drivers side in place?
thanks
Old 05-01-2012, 02:55 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Originally Posted by a lincoln or two View Post
so what have you guys done to keep the height sensors on the drivers side in place?thanks
The original Navi driver's side upper control arm has a little 'bump' cast in it to postion the height sensor. I just measured the distance from the BJ to the height sensor bracket, put a mark on the new control arm and located the height sensor bracket accordingly.
Old 05-01-2012, 03:26 PM
Quote:
thanks for the info. the moogs all say without sir ride. i even tried tasco ford online and the dont list ones for air ride either.
Ball joints sam hain 1997 - 2003 F150 3 01-01-2017 10:31 AM
upper control arms Driton Ranger & B-Series 7 09-04-2014 08:37 AM
2000 Ranger upper ball joint replacement? Guest user Brakes, Steering, Suspension, Tires, & Wheels 2 01-09-2012 12:30 AM
ford ranger ball joint oops Ranger & B-Series 11 04-16-2010 05:59 PM
Bad ball joints ---> Replace other parts also? xgrove 1997-2006 Expedition & Navigator 14 11-23-2009 12:45 PM
Tags
1998, 98, arm, assembly, ball, bracket, control, expedition, ford, height, joint, joints, linclon, navigator, sensor, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
