diesel tachometer - Ford Truck Enthusiasts Forums
diesel tachometer
Old 04-30-2012, 10:22 PM
6.9 diesel nut's Avatar
6.9 diesel nut 6.9 diesel nut is offline
6.9 diesel nut is starting off with a positive reputation.
diesel tachometer
I notice that a lot of lower trim level 80s trucks didn't come with a tach. Is there a way to add one to the gauge cluster where it would have been? I need a tach and it just don't look right with that empty space.
Old 04-30-2012, 11:05 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
If i remember right its quite a job, but should be able to just get a cluster from one with a tach, and the tach signal and wires. I know there are aftermarket ones, but theyre kinda pricey and dont fill the hole.
Old 05-01-2012, 12:00 AM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
You have to make sure you have the correct ip gear cover for the tach, it should have a 1''npt plug in it for a pickup sensor. You have to swap clusters, and it has to be a diesel cluster AND tach.
It wasn't just the lower trim level trucks, mine has every option BUT the tach, key, heat, a/c, criuse, power windows/locks, and even bucket seats, but no tach.
Old 05-01-2012, 12:13 AM
right forgot about the gear cover, did the non tach ones just have no port for the sensor?
Old 05-01-2012, 12:50 AM
Rxracer27 Rxracer27 is offline
Rxracer27 is starting off with a positive reputation.
non tach trucks didnt have the port for the sensor in the housing, although i have seen some of the newer ones that did have the port witha plug.
we just put a tach cluster in my pops 84, we were at the local yard and he found a diesel tach cluster, manual trans w/ trip odometer in some pos f150 gas truck lol.
he snagged it up, we changed housings and ran 4 wires, now he has a tach
not too hard of a job, and really finished his truck
Rob
Old 05-01-2012, 07:49 AM
So am I out of luck when it comes to the tach? Where is the port for it? I really don't want to get a new cluster. Then the odometer would be wrong. I guess i can get a sunpro like what my dad has in his 66 fastback mustang.It still wouldn't look right. It don't make sense to have a diesel and no tach.
Old 05-01-2012, 09:38 AM
It is SOO easy to change the odometer, at the very least you could put your speedo head in the other cluster and you wouldnt even have to change the odometer.
Old 05-01-2012, 12:12 PM
NMB2's Avatar
NMB2 NMB2 is offline
NMB2 is gaining momentum as a positive member of FTE.
That sunpro wont work, you have to have a diesel specific tachometer.
I put this tach in my last truck, I still have it if you're interested...
Auto Meter 2888 - Auto Meter Performance Series Mini Tachometers - Overview - SummitRacing.com
Old 05-01-2012, 06:11 PM
awhtx awhtx is offline
awhtx is gaining momentum as a positive member of FTE.awhtx is gaining momentum as a positive member of FTE.
Where does this tach get it's "signal" from the engine?
Old 05-01-2012, 06:28 PM
NMB2's Avatar
Quote:
Alternator.
Old 05-01-2012, 10:28 PM
turtlemann14's Avatar
turtlemann14 turtlemann14 is offline
turtlemann14 is starting off with a positive reputation.
couldn't you through a tone ring on the crankshaft pully and pick up from there with a hall sensor?
Old 05-01-2012, 11:04 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
I got a factory tachometer from da 80's model (pre-87) if you want it....
Old 05-02-2012, 07:51 AM
I did some searches last night and I'm thoroughly convinced that there ain't much for these trucks.I did look under the hood and there is this round connector plug comming off the alternator. It ain't hooked up to anything. Is that for the Tach?
Old 05-02-2012, 11:05 AM
NMB2's Avatar
Quote:
No, the autometer tach has a pickup that you strap onto the alternator.
Old 05-03-2012, 06:04 PM
snowracer snowracer is offline
snowracer is starting off with a positive reputation.
on my 7.3 when i pulled the dash out i just ran a dakota digital box off the alternator and have it hooked up to my autometer gauge. works real well and is tunable if you have a timming light for the idi so you can dial it right in
Another instrument cluster question eagle275 1987 - 1996 F150 & Larger F-Series Trucks 3 06-19-2015 11:31 AM
Autometer Diesel Tach Alternator Probe. Doing 3G Swap...Do I need to recalibrate the tach? genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 05-08-2015 06:47 AM
What does the crank sensor "talk" with brobrad 1997 - 2003 F150 12 01-15-2013 05:10 PM
Tach not working broodog Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 12-01-2011 11:30 AM
Factory tach wiring questions. scottscott 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 04-22-2010 05:08 PM
Tags
1989, 1990, 67, 69, 73, diesel, electric, f250, ford, idi, pu, put, rpm, signal, tach, tachometer, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
