Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-30-2012, 09:11 PM
dgruhlke dgruhlke is offline
2007 Ford Expedition
dgruhlke is starting off with a positive reputation.
2007 Expy Rear Differential Friction Modifier?
Hello-
I just changed the rear differential fluid in my 2007 Expedition. From what I can tell the 2007s and newer do NOT have limited slip differentials, they have traction control. When the truck is jacked up and I spin a tire one way, the opposite tire spins the other way. Per the manual, the friction modifier is only needed on models with the limited slip. This is a bit confusing since it's not offered I don't know why they put that in the manual... but my question is am I right about this that I don't need the friction modifier?
Thanks!
  #2 (permalink)
Old 04-30-2012, 09:35 PM
critterf1's Avatar
critterf1 critterf1 is offline
Garage is empty, add now
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Should not be needed.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 05-01-2012, 10:23 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Whats the manual say? If it says add it I would.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #4 (permalink)
Old 05-01-2012, 11:22 AM
Tylus's Avatar
Tylus Tylus is online now
Nuke Mechanic
2006 Ford F-250
Tylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant future
No LS in the 07+ Expy
Just put the spec'd dif fluid. No modifier needed
__________________
United States Navy - Bubblehead
2002 Excursion XLT w/ V-10 <-- The new toy
2012 Flex Limited <-- 17 mpg city, 27 mpg highway
Tags
06, 2007, change, diff, differential, diiferential, expedition, f150, fluid, ford, friction, modifier, modifyer, rear, slip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
