Need a new fuel pump...
Hey guys, if the tank in the front gets low, she won't run. When the wacky fuel return from the rear fills the front, she'll start. Most likely a bad pump?
It's the original, so I'm guessing it needs to go. Any reputable brands? I'd go motorcraft, but something like $350 for the pump and sending unit is a but steep. Airtex, Bosch, Carter?
Appreciate the help guys
I honestly don't know the answer to that one, my own truck is a 1981 and I flip a switch. In either case, though, there will exist a mechanism of flipping both the source & return lines from one tank to the other, and, even if it's automated, I'd guess it would still be possible for at least part of that valve to stick.
No?
Manual valve? As in, you don't flip a switch to change from one tank to the other, everything is done *for* you? That would scare me....
No?
No?
Thanks Tank. Is FDM considered just the pump, or is that the whole.pump and sending unit package together?
Anybody? I know that ford sells the pump, and the connecting tubes together as one unit, versus companies like Spectre selling the tube inputs and then the pump separate. I will most likely go for the Ford unit, but its a hefty price. I see Bosch sells the pump, but I only see the pump itself, not the top input tube and electrical connection. Any help here?
If it matters, I have the 19 gallon steel front tank, and the 18 gallon steel rear tank
Boss F150
40
07-18-2016 07:31 AM
