72 360 Timing Mark - Ford Truck Enthusiasts Forums
72 360 Timing Mark
Old 04-30-2012, 07:29 PM
jdsunset jdsunset is offline
jdsunset is starting off with a positive reputation.
Question 72 360 Timing Mark
I have recently bought a 72 F250 Camper Special with rebuilt 360. It will not Idle when hot and I am trying to get the carb and timing dialed in and can not find the timing mark on the crank pulley. Can anyone give me a clue. Thanks JD.
Old 05-01-2012, 08:25 AM
Alex from GA Alex from GA is offline
Alex from GA is starting off with a positive reputation.
Put the engine on #1 cylinder and look carefully at the pulley. Use some white paint in the groove. To find #1 cylinder put a wood dowel down the spark plug hole and move the crank, by hand, until the piston is at the top. Make sure the valves are both closed. Did you do a compression check?
Old 05-02-2012, 06:24 PM
tmcalavy tmcalavy is offline
tmcalavy is gaining momentum as a positive member of FTE.
They're there, probably just covered by rust and gunk. Get up under the truck with some rags, carb cleaner, steel wool and some sandpaper. Clean the edge of the crank pulley with rags and carb cleaner, then do the steel wool and finally the sandpaper. Don't worry, you can't rub them off. Might take some looking but you'll find them after the pulley edge is cleaned up. Last step is to take a piece of kid's sidewalk chalk and rub generously over the timing marks...this gets white chalk down into the marks so they are easier seen with the timing light. Good luck and sweep for rocks under the truck before you start...you'll be under there awhile.
Old 05-02-2012, 08:36 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
FE engines have a timing pointer, it may be missing, or the tip has snapped off.
C9AZ-6023-A (replaced C3AZ-6023-A) .. Timing Pointer / Obsolete
Applications: 1963/71 Ford/Mercury Passenger Cars / 1965/76 F100/350 except 1972/76 F100 360's sold new in CA (DSO code 71 or 72).
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
PEROGIE ENTERPRISES in Highstown NJ has ONE = 609-448-5593.
Tube toothpaste, once it dries, can also be used to highlight timing marks.
360 header/starter clearance? FLgargoyle FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 03-03-2014 09:42 AM
Timing mark for 1970 360 abe 1967 - 1972 F-100 & Larger F-Series Trucks 5 03-10-2013 10:22 PM
timing ? divinusmonstrum 1967 - 1972 F-100 & Larger F-Series Trucks 11 10-22-2012 09:36 PM
72 F100 Plow Truck Brendan Brooks 1967 - 1972 F-100 & Larger F-Series Trucks 7 03-01-2012 09:25 AM
Time question 360 Kennewick FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 09-12-2009 09:39 PM
Tags
1969, 360, 460, 72, 73, big, block, cam, ford, fordtrucks, idi, marks, procedure, set, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
