215/75r15 for the front and 275/60r15 on rear? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-01-2012, 08:49 PM
tmcalavy tmcalavy is offline
tmcalavy is gaining momentum as a positive member of FTE.
Small, narrow up front and wider, taller on the back was quite common back when I was in high school...won't say how many decades ago that was, but Kennedy was in the White House. We did it for the hot rod look...it handles worse IMO and you lose some mpg cause you're exposing more of the "brick" shape to aerodynamic drag...but it does look way cool. You also have to be careful of not going too small/thin on the fronts, cause those wheels carry the bulk of the truck weight...no curb hopping, etc.
Old 05-01-2012, 11:35 PM
davidmoss1992 davidmoss1992 is offline
davidmoss1992 is starting off with a positive reputation.
No sorrys needed, honest mistake. Would 235-75r15s on the front with 255-70r15s on the back look good, that way I get a little wider in the back. I do use the truck as a truck every once in awhile. I am also looking for that hotrod look on my truck that many seek out in highschool. Thank you very much for taking the time to help me out
tire and rim info brutus67 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-23-2015 12:27 AM
10 inch wide rears backspacing - ANSWERED!! MaxPowers 1967 - 1972 F-100 & Larger F-Series Trucks 5 08-27-2014 11:18 AM
275/60/R15 Tires Toplait 1987 - 1996 F150 & Larger F-Series Trucks 5 03-18-2014 06:57 PM
1973 +5 wheel and tire fitment question jakerz 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-15-2011 08:05 PM
P255/60R15 VS. P275/60R15 MattyJessome 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-17-2011 09:52 PM
Tags
25570r15, 275, 27560r15, 27575r15, 2wd, 60r15, 75r15, big, f150, ford, good, lt215, ranger, small, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
