Virginia's Official May and Play BS/Chat Thread!
#139
Thanks, Shaun.
Motorcraft: RT-139
Bottom needs to look like this
so that the bypass is closed off when it opens.
Motorcraft: RT-139
#140
Find TDC
pull it
knock the roll pin out of the gear
Mark the gear. white stripe on it and the shaft
push off the gear
Pull the whole thing up through the top.
unscrew and remove the pickup/ reluctor
Re assemble.
adjust air gap with non magnetic feelers
Put back in
Set timing with vacuum line off and plugged to 10* btdc
Varooom!!! varoom!!!!
#142
You may also have a problem, most are 180*, 195*, and 210* Not 192*
#143
George I have used the fail safe thermostats before. I like them. Cost a fe bucks more but better peace of mind.
#144
Yeah, I know.
#145
Motorcraft RT351 - 180F
Motorcraft RT350 - 160F
Rober Shaw makes the correct thermo, so if you can't find one, I'll get one from them.
#146
Went to the pull today. 14 trucks, all efi or v8. 31 Taurus, all efi.
Did find a parking brake assembly that works and a factory am/fm/cass. Total was $12 haha.
Put out one fire for the night. 72 minutes on the phone. ugh. Family is home, fire #2.
Guy left me a message while I was MIA this morning about some fixit/lawn work. When I called him back his voicemail includes "property manager" If I get something in writing I'll be excited.
#150
Dave I was out at Fort Frederick for the market fair on sunday. Picked up a few things. I do have something in the wings though. Details willfollow as soon as I have them.
