Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1948 - 1956 F1, F100 & Larger F-Series Trucks Discuss the Fat Fendered and Classic Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 04-30-2012, 05:22 PM
bk53 bk53 is offline
1953 f100 w/flathead v8
1953 Ford F-100
bk53 is starting off with a positive reputation.
Hi newb with question
Hi I've been lurking around for a few months. I drive a 53 f100 with a 239 and fordomatic. load-o-matic dizzy h94 etc. I've got an issue with wear on the slip yoke. I think the part I need is a b5c 4841-a First I'm not sure of the pn second, i've called all over and searched and apparently this is a pretty rare part. I could use a lead if anyone has one. Third can I have this machined or chromed or anything to bring it back? can I mabbe sand it down and use an oversized seal? some trick to put the worn spot somewhere other than right at the seal?
appreciate any help or ideas you can share.
Regards,
Bill
Rowlett Tx
  #2 (permalink)
Old 04-30-2012, 06:20 PM
oldmerc's Avatar
oldmerc oldmerc is online now
oldmerc
Garage is empty, add now
oldmerc is gaining momentum as a positive member of FTE.
If it's just worn where the seal rides then have your locale bearing shop get you a speedi sleeve/seal kit . that should cure a leak problem 9 times out of 10 .
__________________
ALLAN
49 MERCURY M68
  #3 (permalink)
Old 04-30-2012, 06:24 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a very good reputation on FTE.tinman52 has a very good reputation on FTE.tinman52 has a very good reputation on FTE.
Try to find a good drive line shop or machine shop near you.....that is how I found a new yoke for my 3 speed. Do you know the spline count and u joint type?
You may also be able to put a speedy sleeve on for the seal to ride on...
And welcome to FTE!
__________________
Scott
'99 F250 SD 4x4
'62 F100 4x4
'52 F-1 "old blue"
My COE build thread;
http://www.ford-trucks.com/forums/11...uck-build.html
  #4 (permalink)
Old 04-30-2012, 06:34 PM
oldmerc's Avatar
oldmerc
Sorry I forgot to welcome you to the group . These guys are a great source of helpful advice and knowledge .
__________________
ALLAN
49 MERCURY M68
  #5 (permalink)
Old 04-30-2012, 06:38 PM
1953 Ford F-100
speedy sleeve! someone has thought of dang near everything haven't they? Yeah it a 16 spline and I just threw out the u joint box. Thanks for the welcome.
Bill
  #6 (permalink)
Old 04-30-2012, 11:33 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a good reputation on FTE.ben73058 has a good reputation on FTE.
Hey Bill,
Welcome Aboard! Quite a few of us down around Austin - Put some pics
up when you get a chance. Would love to see your truck. My truck is up in Waco - My son at Baylor borrowed it for a weekend about 8 weeks ago...
Ben in Austin
1950 F1
  #7 (permalink)
Old 04-30-2012, 11:51 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
1952 Mercury M-1
52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.52 Merc has a great reputation on FTE.
Hi Bill, welcome to the forum! My old Ford parts catalog shows 53-54 F-100 Fordomatic slip yoke being part number TAAA 4841 B. 1955 used the B5C 4841 B. That's not to say the earlier number wasn't superceded by the later number, because it likely was. It's also very likely been superceded since then, as well. Ford is famous for changing numbers on parts. It at least gives you another option to look for. That same yoke was also used with overdrive manual transmissions, too. But the speedy-sleeve option will probably be your easiest, cheapest, and fastest solution.
__________________
Wayne
52 Mercury M-1
among other things.
Tags
b5c4841a, b5c4841b, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
