speedo reading high
Check out transmissioncenter.net it gives a lot of info how to determine gears with rear end ratio and tire size. It may help or not, worth looking at.
Hey Wisconsin,
If you don't get where you want by swapping out the
speedo gears - there is a different route I learned about in
trying to get our's to work. We've got a wireless programmable speedo -
It's pretty neat. You put whatever speedo gear you want in your trans &
you put the wireless sender unit in where the cable would go on the trans. & you go out to a highway with known distance markers. You punch the setup button & drive it two miles at 45 MPH or so & it calibrates itself & you get the right speed showing on your speedometer.
This was my first experience with these programmable speedos & it certainly worked like a champ. I got mine from Egauges.
Good luck over there.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
KsHighboy
19
03-29-2016 05:46 PM
customfoam
12-19-2004 05:15 PM
71LTD390
09-01-2004 08:13 AM
jimandmandy
11-13-2002 10:24 PM
