2008 6.4L Found 3 Oil Leaks Today - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 04-30-2012, 05:02 PM
F250GH F250GH is offline
F250GH is starting off with a positive reputation.
The dealer located 3 oil leaks on the engine today. Upper pan gasket, lower pan gasket, and rear main seal. Job will take 2 complete days to complete.
The good news is, there's 27 days left in the warranty.
How could three seals let go at once?
Old 04-30-2012, 05:21 PM
SUPERDUTY_08 SUPERDUTY_08 is offline
SUPERDUTY_08 is starting off with a positive reputation.
i just noticed a wet spot under my 2008 today. I crawled under to see more wet spots on engine parts/steering parts. It seems to be a clear oily substance, and looks like it is coming from the lower radiator hose. I looked at the coolant reservoir and looks to be the same as the wet spots. Does this sound about right to anyone?
Old 04-30-2012, 09:39 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Quote:
check your uppper radiator hose at the thermostat housing
Old 04-30-2012, 10:17 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Wow. Three new seals less than a month before warranty expires. I wouldn't care about how three went out simultaneously, I'd just be greatful.
Old 04-30-2012, 10:45 PM
Quote:
thanks I will check that tomorrow (if its not raining), otherwise i am dropping it off to the dealer wed night.
Old 05-01-2012, 06:16 AM
senix's Avatar
That is the problem with bed plate design that navistar uses.
Mine is ok.
Old 05-01-2012, 04:12 PM
t613's Avatar
t613 t613 is offline
t613 is starting off with a positive reputation.
Mine had an upper bed plate leak too. Thank you for the warranty Ford!!! They took the cab up, motor out and sealed/replaced bed plate.
Old 05-01-2012, 07:36 PM
Exactly what is involved to replace these???
Old 05-02-2012, 08:07 AM
t613's Avatar
They don't replace the bedplate itself, just re-seal above and below it. The only way to get to it is to pull the engine (which means pulling the cab) and removing the oil pan and bed plate itself.
The mechanic that did mine was very confident that it would not leak again with the black RTV that was used. It was only a heavy seep, but there was a visible oil trail down to the bottom of the bell housing.
Get it checked out and repaired if you still have a warranty left!
Old 05-02-2012, 11:20 AM
Mine is being done now. The cab was removed first, then motor was removed. Seems to be the only "correct" way to complete the job.
Pretty impressed with the whole procedure being done by the dealer.
Screwy Ford design though.
Old 05-02-2012, 11:42 AM
RM2738's Avatar
It's truly designed by International with input/support from Ford engineers I believe.
Old 09-30-2012, 09:12 PM
xpl0sive xpl0sive is offline
xpl0sive is starting off with a positive reputation.
I just located some wet spots under my truck today. i'm guessing it's either the lower pan gasket or the rear main seal leaking... are these seals covered under the 5/100 power train warranty?
Old 10-01-2012, 02:16 AM
KPBJJ KPBJJ is offline
KPBJJ is starting off with a positive reputation.
I have a similar leak. Any ideas if this is a bedplate leak or rear main seal. Coming out of rubber pieces one by external Trans filter and the other above the oil pan.
Old 10-01-2012, 07:28 AM
senix's Avatar
If it is from the motor then it will be covered under the diesel motor warranty. Most likely they will clean it and put some dye in the oil to find the leak.
this type of repair though you can plan it out so you are not without the truck when you need it most.
Old 10-01-2012, 06:21 PM
ETKMS's Avatar
ETKMS ETKMS is offline
ETKMS is starting off with a positive reputation.
Quote:
Mine is doing the same thing. I tow and been driving like that for a year. Its the bed plate likely. Mine is not losing enough oil to even drip on my driveway. No way will i have them cab off and engine out again to fix it unless it gets worse. I once had the front cover leaking oil, they replaced that, that was leaking a nice amount though, left drops everywhere on my driveway.
Oil leak on a 300 dyoungen Ford Inline Six, 200, 250, 4.9L / 300 6 06-03-2013 06:15 PM
352 FRONT OF MY ENGINE LEAKING OIL... Mean66 1961 - 1966 F-100 & Larger F-Series Trucks 7 06-11-2012 01:19 AM
cant stop oil leaks! 78_f150 1973 - 1979 F-100 & Larger F-Series Trucks 19 10-18-2011 12:03 AM
79 f250 custom 300 six cyl oil pan leaks 4rdnut 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-30-2011 02:38 PM
1998 F150 OIL PAN LEAK robjs111 1997 - 2003 F150 5 04-01-2011 09:19 PM
Tags
60, 64, bedplate, diesel, drain, fix, ford, hose, leak, lower, oil, radiator, rtv, seal, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
