6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 6.4L Found 3 Oil Leaks Today
Old 04-30-2012, 04:02 PM
F250GH's Avatar
F250GH
F250GH is offline
The dealer located 3 oil leaks on the engine today. Upper pan gasket, lower pan gasket, and rear main seal. Job will take 2 complete days to complete.
The good news is, there's 27 days left in the warranty.
How could three seals let go at once?
Old 04-30-2012, 04:21 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
SUPERDUTY_08 is offline
i just noticed a wet spot under my 2008 today. I crawled under to see more wet spots on engine parts/steering parts. It seems to be a clear oily substance, and looks like it is coming from the lower radiator hose. I looked at the coolant reservoir and looks to be the same as the wet spots. Does this sound about right to anyone?
Old 04-30-2012, 08:39 PM
senix's Avatar
senix
senix is offline
Received 1,406 Likes on 1,002 Posts
check your uppper radiator hose at the thermostat housing
Old 04-30-2012, 09:17 PM
RM2738's Avatar
RM2738
RM2738 is offline
Wow. Three new seals less than a month before warranty expires. I wouldn't care about how three went out simultaneously, I'd just be greatful.
Old 04-30-2012, 09:45 PM
SUPERDUTY_08
thanks I will check that tomorrow (if its not raining), otherwise i am dropping it off to the dealer wed night.
Old 05-01-2012, 05:16 AM
senix's Avatar
senix
senix is offline
That is the problem with bed plate design that navistar uses.
Mine is ok.
Old 05-01-2012, 03:12 PM
t613's Avatar
t613
t613 is offline
Mine had an upper bed plate leak too. Thank you for the warranty Ford!!! They took the cab up, motor out and sealed/replaced bed plate.
Old 05-01-2012, 06:36 PM
F250GH's Avatar
F250GH
F250GH is offline
Exactly what is involved to replace these???
Old 05-02-2012, 07:07 AM
t613's Avatar
t613
t613 is offline
They don't replace the bedplate itself, just re-seal above and below it. The only way to get to it is to pull the engine (which means pulling the cab) and removing the oil pan and bed plate itself.
The mechanic that did mine was very confident that it would not leak again with the black RTV that was used. It was only a heavy seep, but there was a visible oil trail down to the bottom of the bell housing.
Get it checked out and repaired if you still have a warranty left!
Old 05-02-2012, 10:20 AM
F250GH's Avatar
F250GH
F250GH is offline
Mine is being done now. The cab was removed first, then motor was removed. Seems to be the only "correct" way to complete the job.
Pretty impressed with the whole procedure being done by the dealer.
Screwy Ford design though.
Old 05-02-2012, 10:42 AM
RM2738's Avatar
RM2738
RM2738 is offline
It's truly designed by International with input/support from Ford engineers I believe.
Old 09-30-2012, 08:12 PM
xpl0sive's Avatar
xpl0sive
xpl0sive is offline
I just located some wet spots under my truck today. i'm guessing it's either the lower pan gasket or the rear main seal leaking... are these seals covered under the 5/100 power train warranty?
Old 10-01-2012, 01:16 AM
KPBJJ's Avatar
KPBJJ
KPBJJ is offline
I have a similar leak. Any ideas if this is a bedplate leak or rear main seal. Coming out of rubber pieces one by external Trans filter and the other above the oil pan.
Old 10-01-2012, 06:28 AM
senix's Avatar
senix
senix is offline
If it is from the motor then it will be covered under the diesel motor warranty. Most likely they will clean it and put some dye in the oil to find the leak.
this type of repair though you can plan it out so you are not without the truck when you need it most.
Old 10-01-2012, 05:21 PM
ETKMS's Avatar
ETKMS
ETKMS is offline
Mine is doing the same thing. I tow and been driving like that for a year. Its the bed plate likely. Mine is not losing enough oil to even drip on my driveway. No way will i have them cab off and engine out again to fix it unless it gets worse. I once had the front cover leaking oil, they replaced that, that was leaking a nice amount though, left drops everywhere on my driveway.
Quick Reply: 2008 6.4L Found 3 Oil Leaks Today
