Bug KILLER !!!!!!!!!!!!
Old 04-30-2012, 11:33 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Ok, making the trip at night down to College Station before heading thru Houston to lunch with Torreador Diesel and on to Lafayette, La made for a much shorter drive the next day, BUT
A gazilion bugs are now on the front of our new truck and 5th wheel....
The truck went through the car wash and so it's good,
but what do I do for the 5th wheel ?
I am past when I want to do it myself but will if I have to
Sooooo...do I:
Pay the highway robbery to have it washed at the dealer?
find a truck wash and see how much they charge ?
get some steel wool and sandpaper ?!?
or simple green, or ?~?
open to suggestions as I tried my little wash brush and it didn't dent the bugs...
then once cleaned, how do I make it easier the next time ?
Old 04-30-2012, 12:30 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
Triple wax it!
Old 04-30-2012, 01:15 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
power washer and stay away from the windows. Lower pressure nozzles.
Old 04-30-2012, 01:54 PM
jdadamsjr's Avatar
jdadamsjr
Guess best advice is not drive at night
I could SEE the butterflies, etc, dive bombing us !!!
Hmmm, think there is a high coin operated car wash close...
or should I just buy a power washer ?
Would a 1500 psi be the right size or ????
What about the vinyl decals - assume be careful with them
Old 04-30-2012, 02:09 PM
senix's Avatar
senix
senix is online now
I have power washed mine a few times. mine is 2600 psi with the max nozzle. So I guess with my other nozzle it is about 1500 psi.
I have not had any problems.
I have a soap setting to spray that on the 5er then I have a long handle soft brush as well I can stand there and run it up and down on the really hard spots then spray.
Has worked well on those 2-3K bug runs.
Old 04-30-2012, 05:22 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Just wet the dryer sheets you use in your clothes dryer and wipe em over the front when you wash it and the bugs will come right off. Works on cars, trucks, anything, even when the power washer doesn't!
Steve
Old 04-30-2012, 06:34 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Neat hint!!!! Thanks Steve!
Old 04-30-2012, 09:12 PM
jdadamsjr's Avatar
jdadamsjr
Atta Boy !!!
Now I just need a 20 foot by 20 foot dryer sheet and I got it made
Will give it a try !
and had heard that a long time ago, but forgot about it !!!
Old 05-01-2012, 07:13 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Originally Posted by jdadamsjr
Atta Boy !!!
So you don't have a dryer in that little fiver you are towing? Just put it in the bed of your truck!
Steve
Old 05-01-2012, 07:56 AM
jdadamsjr's Avatar
jdadamsjr
No washer dryer by choice and good thing since certainly you understand that it turns out that the washer/Dryer closet is the only space left for MY hanging clothes
Thanks
Old 05-13-2012, 05:10 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,495 Likes on 1,304 Posts
Steve
Thumbs up, bugs came right off using the wet sheets.
Old 05-13-2012, 05:14 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
You doubted me? I'm crushed!
Old 05-13-2012, 06:52 PM
LibTimothy's Avatar
LibTimothy
LibTimothy is offline
I just bought a box of dryer sheets just to clean my RV. I hope i get time to try this before my next trip.
Will the cheap sheets work?
Timothy
Old 05-13-2012, 07:00 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Timothy
I'm not sure brand makes a difference. I just steal whatever my wife has in the laundry room, use em, then sneak the rest back. Sometimes I forget and she finds them in the garage.
Steve
Old 05-13-2012, 08:54 PM
rvpuller's Avatar
rvpuller
rvpuller is online now
First I never power wash the front or any other part of our trailer it's just to hard on the decals. I always keep a good wax job or in my case a polish job (I use Nu-Finish polish). When I get a load of bugs I rehydrate them with water or a light solution of water and Dawn soap, I reapply ever 15 minutes and use a brush to clean them off, if it's really bad I use Simple Green and a sponge and polish the front because the Simple Green will remove any wax or polish. The longer you leave them on the harder they come off and some of the little buggers will damage the finish.
Denny
Quick Reply: Bug KILLER !!!!!!!!!!!!
