Starting Problem
Starting Problem
I have a '93 F250 4X4 HD with a 460 and E4OD. Three different occassions after sitting all day, not all night, the engine has started and immediately stalled.
Yesterday it did it twice in a row and then started up fine. I was thinking either something electrical like the coil or maybe PCV valve?
Somebody have any ideas,
Geoff C.
Geoff C.
Starting Problem
The PCV valve isn't electrical.
Pull the codes to see if the IAC or ignition module is acting up. Then put a fuel pressure gauge on it (hanging out the back of the hood so you can see it when you sit in the truck) & crank it. Just leave it in there for a week if you need to until the problem repeats a few times.
