Homemade Fuel tank Until I Get New Tanks/Valve? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-07-2012, 12:41 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Diesel and wvo don't mix properly, so you will be going back to the same mess you just had. Also, need to be real sure it is filtered good enough, as there will be water and particles in the wvo. It is likely that is where all of your troubles came from, might also be hard on the rubber lines.
Old 05-07-2012, 06:23 AM
linus72's Avatar
linus72 linus72 is offline
linus72 is starting off with a positive reputation.
Well, I gather the oil from Asian joints, and it's mostly clear unfiltered and passes the crackle test easily. I filter it till it resembles honey.
This is only temporary- by the end of this week I plan to have a pre-heater and extra filtering on the truck.
What will mix with WVO?
Old 05-07-2012, 07:28 AM
fellro86's Avatar
Typically they are run in separate tanks, the diesel in one, wvo in the other. That minimizes mixing. If you go the biodiesel route, then you can blend it with regular diesel.
Read up in this forum, they can tell you much better than I can.http://www.ford-trucks.com/forums/forum168/
Ditching the dual fuel tanks fordtrucksforever Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 02-24-2016 08:29 AM
Installing Electronically Controlled Fuel Tank Selector Valve 1988 Ford F150 Matt Cherry Fuel Injection, Carburetion & Fuel System 2 06-27-2014 05:00 PM
Question on fuel selector valve - dual function reservoir SSellers 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 12-24-2013 12:47 AM
Fuel tank selector valve - how to test. Myfreeford 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-05-2011 01:20 PM
Diagram for fuel selector valve operation flainn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 06-05-2011 08:20 AM
Tags
45, disell, flathead, gas, handmade, homemade, l3004x4, lightning, lights, make, northern, tank, temporary, til, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
