Annoying Squeek
Old 04-25-2012, 10:58 AM
kwaskow's Avatar
kwaskow
kwaskow is offline
Annoying Squeek
I can usually track these down, but this one is eluding me. It seems to be coming from the rear passenger side and really only bad when turning left or veering left at slow speeds.
Old 04-25-2012, 11:43 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Find someone with a "ChassisEar", safest and quickest to isolate noises like this... Philip
Old 04-25-2012, 12:21 PM
shorod's Avatar
shorod
shorod is offline
A ChassisEar would definitely help here. Can you determine if the noise seems to be interior or exterior? What year and sub-model is your Explorer? I've seen quite a few Sport sub-models with loose (rusted) running boards.... I've also experienced that noises, especially interior noises, can easily telescope and sound like they're coming from a completely different area.
-Rod
Old 04-25-2012, 01:42 PM
kwaskow's Avatar
kwaskow
kwaskow is offline
I believe it is exterior and it is a 2003 Mountaineer V8 AWD
Old 04-25-2012, 10:27 PM
shorod's Avatar
shorod
shorod is offline
The noise may be a wheel bearing, I've read of quite a few folks replacing rear wheel bearings no the 2002 and newer.
-Rod
Old 04-26-2012, 09:08 AM
kwaskow's Avatar
kwaskow
kwaskow is offline
This seems more consistent with a suspension or body panel issue, the truck needs to be bouncing a bit for the squeek to occur
Old 04-26-2012, 02:02 PM
shorod's Avatar
shorod
shorod is offline
I have seen on several occasions a dry ball joint or outer tie rod end on older Fords get dry and squeak. All that I have seen were on the front, and the newest I encountered was a 1998 model year. My method for identifying which part was the culprit was to use a small pick to poke a small hole in the dust boot of one of the joints. Then I inserted the straw from an aerosol can of white lithium grease through the hole and gave it a squirt. Remove the straw from the hole and bounce the vehicle a few times. If the sound changed or vanished, I knew I found the right part. It never took more than a bounce or two to notice a change in sound once I found the noisy joint.
There's nothing saying the same couldn't/wouldn't apply to the rear ball joints in your Explorer, but also don't necessarily rule out that it could be coming from the front. A second person standing outside the truck may be able to more clearly identify at least which corner of the vehicle the noise is coming from.
-Rod
Old 04-26-2012, 03:08 PM
kwaskow's Avatar
kwaskow
kwaskow is offline
good advice, thanks
Old 04-27-2012, 04:31 AM
ukexplorer's Avatar
ukexplorer
ukexplorer is offline
Rear spring shackle rusts very badly. Especially the one by the exhaust pipe. Replace.
Old 04-30-2012, 09:30 AM
kwaskow's Avatar
kwaskow
kwaskow is offline
My 03 does not have a srping shackle, does it?
Old 04-30-2012, 09:51 AM
ukexplorer's Avatar
ukexplorer
Sorry, I thought you may have the old cart springs at the rear like mine. No, your truck has a different suspension layout and no shackles.
Old 05-01-2012, 07:55 PM
swshawaii's Avatar
swshawaii
swshawaii is offline
Check your frame body mounts. Very common issue and easy to inspect.
They can be extremely difficult to remove due to the amount of Loctite used.
AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - Ford Explorer and Sport Trac Frame/Body Cushions
evanjohn3
06-12-2015 01:28 PM
jamelton
11-20-2014 07:30 PM
rubersole
09-03-2006 03:39 PM
OneShotBandit
04-01-2004 07:20 PM
Quick Reply: Annoying Squeek
