Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-29-2012, 11:13 PM
RoidRanger RoidRanger is offline
Garage is empty, add now
RoidRanger is starting off with a positive reputation.
bad miss, need help
I swapped a 74 302 into a 83 ford ranger i changed the distributor to one from a 79 duraspark. #2 and #5 cylinders dont fire at all i put on new plugs, wires, cap, rotor and changed the coil, still misses. tried new ignition box that didnt work either. all cylinders have 140psi compression. carb is a holley 4160 vacumm secondaries and automatic choke that just got rebuilt. Idle screws are at 1 turn out, float levels are good and powervalve isnt blown. timing is 8 degrees tried 6 doesnt make a difference.im also getting alot of fuel in the oil. everything is stock on the motor except for the carb,intake and headers. what do you guys think? distibutor mabye? thanks.
  #2 (permalink)
Old 05-06-2012, 02:44 PM
Tried some more stuff today pulled valve covers off and pulled rocker arms, no play in valves, no broken springs and the pushrods aren't bent. put a spark tester on and i get spark to all cylinders. even tried a calibrated spark tester and still get spark and the engine runs the same with it on and one cylinder unplugged. Now i really dont know whats going on i even re timed it. I have spark,fuel,air and compression still misses. I know its missing forsure because it still has paint on the 2 header tubes. any ideas? thanks.
Tags
30, 351ci, bad, cylinders, f250, firing, ford, ignition, miss, motor, ranger, spark, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
