Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-29-2012, 08:03 PM
nomad221's Avatar
nomad221 nomad221 is online now
Garage is empty, add now
nomad221 is starting off with a positive reputation.
Stage one mods
What type of mods are needed to support stage one injectors ?
__________________
Greg, 94.5 F250 ECLB 4WD, ZF S5-42, 3.55's 10.5 3 pin LS, PHP chip, 6637, 3" DP to 4" exh, CAT delete, coolant bypass, Rosewood STS, clutch fix, Valair SMF HD, RR HPX, Autometer EGT and boost gauges.
  #2 (permalink)
Old 04-29-2012, 08:08 PM
jg96powerstroker's Avatar
jg96powerstroker jg96powerstroker is offline
1996 Ford F-250
jg96powerstroker is starting off with a positive reputation.
ids say egt gauge , chip, and than let jim fix ya up, i no there is prob more but that is what id do
__________________
Jason-96 crewcab 7.3auto to manual swap, valair clutch,d66,,cross over oil,beans tunes,6637mod,120 idm,3indp,lost kitty,5in stright,6in mitercuts,skyjacker 8in,(fat girl cant ride mod) 37ingoodyears,d60 swap,jvc in dash,rockford sub and at the corners.glowshift gauges.rosewood stage II, t500 hpop, beans fuel, springs, rods, studs, ic, smoked out lens,..... live beans tunes to come...
  #3 (permalink)
Old 04-29-2012, 08:12 PM
redman84's Avatar
redman84 redman84 is offline
2006 Ford Explorer
My Garage
redman84 is gaining momentum as a positive member of FTE.redman84 is gaining momentum as a positive member of FTE.
With your current mods...
Quote:
Originally Posted by jg96powerstroker View Post
ids say egt gauge , chip, and than let jim fix ya up,...
There are other things that will let you really push it hard but you can run stage Is pretty well with what you've already got. An intercooler and HPOP won't hurt anything though.
__________________
Jacob
1996 F-250 Ext Cab XLT 4x4 7.3L PSD: DP Tuner PCM, E4OD-->5 spd, Valair clutch, 3.55 LS, Rosewood stage I's, IDM-120, FPR shim(65 PSI), 6637, no EBPV, 3" DP, gutted kitty 200k
2006 Explorer Eddie Bauer 4.0L 5r55s K&N 99k (hers)
MOΛΩN ΛABÉ
  #4 (permalink)
Old 04-30-2012, 09:42 PM
JamesHajek's Avatar
JamesHajek JamesHajek is offline
JamesHajek is gaining momentum as a positive member of FTE.JamesHajek is gaining momentum as a positive member of FTE.
Probably want to upgrade your clutch as some point... But gauges, exhaust, intake, custom tunes is all you really need... Unless some of your factory parts are worn like the HPOP, fuel system... that sorta thing...
__________________
James
95 F-250 4x4 Automatic, Autometer gauges, 4" duals, Full Force Stage 1's
00 F-350 4x4 ZF6
Tags
injectors, mods, needed, stage, support
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
