Power steering pump brackets - Ford Truck Enthusiasts Forums
Old 04-29-2012, 07:57 PM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
I bought a trashed 76 F150 parts truck for my 66 F100.
The 76 has a power steering 3 speed column and a 390, my 66 has a manual 3 speed column and a 352.
The power steering pump bracket is not mounted correctly on the 390.
Can someone show a pic or a parts diagram showing the belt routing and the spacer size/location on the FE ps brackets.
The truck has a 2 groove wp pully and a 3 groove crank pully. No ac.
Thanks.
Old 04-29-2012, 10:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Here is the illustration from the Ford parts catalog.
The engine in the pictures has A/C but the p. steering bracket and mounting is the same with or without A/C.
Scroll to the bottom for the .pdf link
Click on the .pdf link to view.
Old 05-03-2012, 02:40 PM
Thanks Mike, the problem Im having is that I cant determine how thick the spacers are that I need on a non ac 390 with ps.
2 bolts go into the waterpump housing, at least one of them has a spacer, 1 bolt goes into the front of the block, that bolt also has a spacer.
If I do not get it exactly right the belt will wear out prematurely.
Old 05-03-2012, 08:22 PM
mikeo0o0o0's Avatar
You could "fab" a spacer using washers to get the correct thickness and go from there. Wrap the washer stack with tape to make them easier to install.
Old 05-03-2012, 11:32 PM
Its going to be a little more work than I thought.
My 66 wp housing is not the same as the 76 wp housing. Im going to have to elongate the mounting bracket holes or swap wp housings.
I havent decided what Im going to do yet. I need to see if there is an issue with the alt bracket as well. My alt belt is on the inside groove, the pics of ps pumps Ive seen show the ps belt on the inside groove.
Nothing is easy.
power steering conversion Toakley123 1961 - 1963 F100 Unibody 1 08-08-2016 07:38 PM
1971 F250 power steering and AC conversion Pockets1187 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-06-2016 01:24 PM
Harmonic Balancer Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-30-2014 11:09 AM
pully jeepy 1961 - 1966 F-100 & Larger F-Series Trucks 9 03-04-2014 03:38 PM
which pully does your power steering pump use lsrjf 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-26-2003 07:43 PM
Tags
1979, 1997, 351m, 73, adjust, bracket, diesel, f100, f150, ford, power, pump, steering, tension, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
