You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have found a 1961 f100 uni with a 6cyl 3 on the tree 2wd for 3500. The truck looks nice and seems to have many new parts. is there anything I should know while looking? I have never seen a uni before but am starting to like them more and more. also, are the bed floors wood?
Marc
__________________
1999 early F250 ex-cab psd with a 6-spd zf and 4x4 (sold)
2007 Ram 2500 5.9l Cummins, 6spd, 4x4, quad cab
1997 F250 XLT, reg cab, long bed, 4x4, 5.8
1962 F-100, 292 Y-block, 3 on the tree
Marc
Holy crap, another dude that spells Marc with the correct letters and likes slicks!!!!!
Soon we'll take over the world.
Glad to hear it Marc. Like the guys above said, rust is the major deal. If it has good bones you can do anything. Get yourself underneath it and look around the floors and rear of the cab especially.
Take a screwdriver with you. If you can poke it through any metal you are going to need welding and fab skills to fix it.
Surface rust is no sweat.
Good luck.
Marc
__________________
'08 Super Duty 6.4, '61 Unibody, '63 T-bird, '66 Mustang
'76 F750 Firetruck, '83 F150, '74 F-1004x4 shrtbx
And not enough time to drive 'em.
Marc
If you have a rusted out bed I would suspect the torque box is pretty much gone as well.
__________________
Rob
1962 Ford F100 flat bed 4x4, 223, 4spd.
1962 Ford F100 Unibody with Olds 330 & Jetaway
1944 Ford GPW (Jeep) with 1947-48 Willys L-134
To join the Oregon Chapter, click HERE
Typical places to find rust are:
Front cab support-crawl underneath and look where the bolt comes down through the floor and attaches to the pad on the frame. The stamped tapered box is the front cab support.
Torque Box- Look at the floor behind the seat bottom of the gas tank area. This is the front of the "TB". Look under the truck at the front of the bed area. This is the bottom of the "TB". Poke and bang around the bottom of the "TB". Soft spots and muffler rattle noise indicates rust.
Door pillar: Open the doors look where the botom hinges go into the cab.
Radiator Core Support: Look where the frame bolts go through on sides of the radiator, where the bottom of the grill attaches, and inside front of wheel wells
Cab cap seam/drip rails
Bottom corners of windshield
Hood leading edge
__________________
62 Falcon 2dr
63 Ranchero
01 Saturn SC1 plastic Vega
11 Kia Forte 5
3 Bikes
Hey Guys,
Thanks for the help. I know that the front of the bed has some rust but I was thinking I could cut it out and weld in new metal. Any thoughts?
Marc
__________________
Also, the steps when you open the doors seem to have a few rust holes that look like old problems. I found some weld in parts that I could cut and put it to maintain the look...
__________________
