You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
B&L, what type of Infinity speakers did you install? I just purchased the Infinity 6.5" components. Hopefully these will have more bass than the 5x7 Boston Acoustics that are in there now. I have an Alpine amp running off the OEM deck with a Scosche aux (scosche.com) right now but have on order an Alpine processor.
I am debating on replacing the entire head unit.
Get a small sub built for your truck. Several companies build them. MTX & JLAudio are 2. They come with amps or without. They take up little space & are designed for your truck.
__________________
Howard Never Politically Correct
Ranger Edge 3.0 Alpine9887 hu Yamaha 320 Phoenix Gold Ms275 JL Audio 500 Morel M12 tweets Exodus 6.5s & Skar VVX 10dvc sub 04 F250 Screw 6.0
NRA Benefactor Life member
Yeah, I guess just taking it to stereo shop and getting it set up would be the easiest thing, but it probably won't be the cheapest. I was hoping to keep it simple and cheap, but that's rarely possible.
The speakers I installed are Infinity 6832CF.
__________________
2012 F250 XLT 6.7L Western Edition CC SB 4X4
2009 Ford Taurus Limited AWD
2006 Lund 1900 Pro V SE, Optimax 200
2007 KTM 400 XCW
The stock head unit, or any head unit for that matter, will not drive a sub. You'll need an amp.
To get the signal to the amp, you'll need something like this. All you do is unplug the main connector on the back of your factory radio and plug this into the harness. Now you have line-outs which you can run to a processor, amp or EQ. It's the simplest way to go for less than $50 and it retains all the stock radio functions. However it does not work if you have the amplified THX system already.
How much you spend on the rest is up to you, but you can have some good bass for a few hundred more, if not less.
__________________
2011 F250 6.2L XLT Crew Cab 4x4, 3.73.
Golden Bronze Clearcoat Metallic
2012 Coachmen Freedom Express 292BHDS
ARE Z Series Cap & BedRug Audio upgrade
I am looking to achieve bass as well after trading-in my 2011 F250 Lariat with the sub that I now miss. I knew I had good bass but never that's where it came from. Nor did I care for the space it took-up however. So, what you recommed sounds easy enough. Then, you need an amp and speakers with subs? What would a retail store charge for this labor? $100 on top of thier product?
I just assumed that the FX Lux pkg would have the same sound system - wrong! I guess only Lariat as stock.
