Wheel Spacer? - Ford Truck Enthusiasts Forums
Wheel Spacer?
Old 04-29-2012, 04:12 PM
SuperDuty93's Avatar
SuperDuty93 SuperDuty93 is offline
SuperDuty93 has a good reputation on FTE.SuperDuty93 has a good reputation on FTE.
Wheel Spacer?
So i assume the point of these is so the tires stick out further? Are they a good idea or a bad one? i like the look of the tires coming out of the wells which mine do but id like a little more. So what the positive and negatives of these?
Also is there some that anyone would recomend?
1974 F250 4X4 Std Cab 8' Bed
Old 04-29-2012, 04:22 PM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
I don't trust them but I have seen people run them. If I wanted my tires to stick out more I would get a different set of rims with less back space and a wider rim.
Old 04-29-2012, 07:26 PM
PapaBearYuma's Avatar
PapaBearYuma PapaBearYuma is offline
PapaBearYuma is gaining momentum as a positive member of FTE.PapaBearYuma is gaining momentum as a positive member of FTE.
While they do make the tire stick out farther, I think the primary reason for their existence is to use wheels with different mounting hole patterns, like to convert 8x6.5 to 8x170. They would also function to move a wide tire out to clear when making tight turns.
IMO, I dont like them as they move your weight bearing away from the hub. I'd prefer a wheel with less backset.
Also, I believe our trucks are hub-centric, meaning the load is transferred to the wheels through the hubs, and the adapters are lug-centric
Old 04-29-2012, 11:10 PM
Old 04-29-2012, 11:19 PM
76Hauler's Avatar
76Hauler 76Hauler is offline
76Hauler is gaining momentum as a positive member of FTE.76Hauler is gaining momentum as a positive member of FTE.
I'm running some on the front so I don't rub my radius arms when I turn full lock. I'm running 35's on stock 90's Alcoa's.
Old 04-29-2012, 11:22 PM
OOoooooo nice! Do you have or see how they could cause a problem? And is there a problem with running them in the rear? I have 35"s as well and the front rub but id like the front and rear to both stick outa the wells the same distance...
Also where di you get yours and how much?
Quote:
Old 04-29-2012, 11:47 PM
76Hauler's Avatar
i got mine from a local shop here, called Pick-up Parts in Mission Viejo SoCal. These will add stress on the bearings just like running wide rims with a deep offset. Use lock tite and torque to - I think 90 lbs., double check. These are a temp till' I get wider beams and/ or custom radius arms. People will give your their opinions on these, do some research and you'll see that people use them with success, even desert race teams. The rears should be no prob.
Old 04-29-2012, 11:56 PM
Im getting new bearings this week .. And im running 16X10 rims currently with a -32 offset i believe. might be -27 but still it has a nice offset to them. Also, whats a D44 and or D60 axle lug size?
Old 04-30-2012, 12:44 AM
76Hauler's Avatar
I don't wanna give ya buzz kill, but my trucks 2WD. not sure on lug size.
Old 04-30-2012, 03:17 AM
Myfreeford's Avatar
Myfreeford Myfreeford is offline
Myfreeford is starting off with a positive reputation.
I had them on my little import, but personally I would not use them on these trucks. I would look into wheels that have the offset you want.
Old 04-30-2012, 07:39 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
I'm going with bad idea. Yes, I have used them. Billet spacers are one thing, and safer, as you install longer lugs. Wheel adapters however, are a different animal. Check your local laws to see how much you can have extending past fenders. That may make your decision for you.
pic request: 4" lift on 305/55/20? ufvj217 2009 - 2014 F150 2 11-02-2015 11:07 PM
Mixing tires on a Dually jonrjen 6.7L Power Stroke Diesel 23 09-29-2015 06:50 PM
Tire Sensor Guru Help Needed! RumpityRump 1999 to 2016 Super Duty 1 04-10-2015 08:24 AM
Tire / load / ply questions - Falken WIldpeak AT Tiedrod 1999 to 2016 Super Duty 14 09-29-2012 09:01 PM
Dual tanks and spare tires tom_moss 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 01-24-2001 09:16 AM
Tags
04, dentside, f100, f150, f250, half, inch, ranger, spacer, spacers, wheel, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
